As a HA (and Linux) newbie, I’m impressed with HA. Had a play with OpenHAB, and am finding HA simpler to get going. Now to my problem…
I’ve installed HA on a BananaPi running Raspian, so to get HA autostart upon boot I need to use this guide:
https://home-assistant.io/getting-started/autostart-upstart/
I used the linked script as it was, apart from replacing the “USER” with my “newuser”.
After immediately following the steps at the top of the script file (before rebooting), I can get the service to start with:
~ $ sudo service hass-daemon start
However after rebooting the service is not running. The same command appears to work (Starting service… & Service Started) but it does not start the service which I validated by the UI not being up, and also when stopping the service it reports “Service not running”. Once I re-issue the following commands I can again use the service start command manually:
~ $ sudo update-rc.d hass-daemon defaults
~ $ sudo service hass-daemon install
Am really hoping someone can help. tips / log file locations?
Thanks heaps…
