Av not found
I get this error:
2019-11-02 19:22:02 INFO (SyncWorker_10) [homeassistant.util.package] Attempting install of av==6.1.2
2019-11-02 19:22:11 ERROR (SyncWorker_10) [homeassistant.util.package] Unable to install package av==6.1.2: Failed building wheel for av
2019-11-02 19:22:11 ERROR (MainThread) [homeassistant.setup] Setup failed for stream: Requirements for stream not found: [‘av==6.1.2’].
but I’ve already installed a newer version inside the virtualenv:
pip3 install av
Installing collected packages: av
  Running setup.py install for av ... done
Successfully installed av-6.2.0
Why it doesn’t find it?
I’m getting a very similar error since updating to v0.101.2:
Testing configuration at /srv/homeassistant/pifour_hass/config
INFO:homeassistant.util.package:Attempting install of av==6.1.2
ERROR:homeassistant.util.package:Unable to install package av==6.1.2: Failed building wheel for av
Command "/srv/homeassistant/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-yonm4rpl/av/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-2sjgc03k/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/include/site/python3.7/av" failed with error code 1 in /tmp/pip-install-yonm4rpl/av/
Failed config
Running under VENV, if you manage to fix it please let me know, I’ve had to disable my camera for now. :frowning:
same issue here under 101.3
  Running setup.py clean for av
Failed to build av
  Running setup.py install for av ... error
    Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-b55gjnz3/av/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-zxdowv5l/install-record.txt --single-version-externally-managed --compile:
    running install
    running build
    running build_py
    creating build
    creating build/lib.linux-armv7l-3.7
    creating build/lib.linux-armv7l-3.7/av
    copying av/__init__.py -> build/lib.linux-armv7l-3.7/av
    copying av/deprecation.py -> build/lib.linux-armv7l-3.7/av
    copying av/datasets.py -> build/lib.linux-armv7l-3.7/av
    copying av/__main__.py -> build/lib.linux-armv7l-3.7/av
    creating build/lib.linux-armv7l-3.7/av/video
    copying av/video/__init__.py -> build/lib.linux-armv7l-3.7/av/video
    creating build/lib.linux-armv7l-3.7/av/container
    copying av/container/__init__.py -> build/lib.linux-armv7l-3.7/av/container
    creating build/lib.linux-armv7l-3.7/av/codec
    copying av/codec/__init__.py -> build/lib.linux-armv7l-3.7/av/codec
    creating build/lib.linux-armv7l-3.7/av/subtitles
    copying av/subtitles/__init__.py -> build/lib.linux-armv7l-3.7/av/subtitles
    creating build/lib.linux-armv7l-3.7/av/filter
    copying av/filter/__init__.py -> build/lib.linux-armv7l-3.7/av/filter
    creating build/lib.linux-armv7l-3.7/av/audio
    copying av/audio/__init__.py -> build/lib.linux-armv7l-3.7/av/audio
    creating build/lib.linux-armv7l-3.7/av/data
    copying av/data/__init__.py -> build/lib.linux-armv7l-3.7/av/data
    running build_ext
    running config
    Could not find libavformat with pkg-config.
    Could not find libavcodec with pkg-config.
    Could not find libavdevice with pkg-config.
    Could not find libavutil with pkg-config.
    Could not find libavfilter with pkg-config.
    Could not find libswscale with pkg-config.
    Could not find libswresample with pkg-config.
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-b55gjnz3/av/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-zxdowv5l/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-install-b55gjnz3/av/
Same here, but solved by installing the dependencies packages:
apt-get install libavformat-dev libavdevice-dev
I may have forgoten one package…
What OS are you running please? And how did you know what packages to install?
Debian here (ubuntu should be the same). The packages was listed on the pip output:
Since pip was trying to compile the av module you will need the “-dev” packages too. Apt-get will install more packages as they are needed by the two ones that I listed.
Ok, thanks, I’l try installing those. I’m using Raspbian which is also debian based so hopefully I’ll be able to fix this error.
Thank you very much, this made the trick. It was super long to install but in the end it worked.
Anyone figure this out using Venv on a Mac?
edit: Figured it out…
  1. brew install pkg-config
  2. pip3 install av==6.1.2
Thanks @Jer78 this worked for me as well! :slight_smile:
working after installing the packages
Thanks!!! solved my problem on ubuntu 16.04. :smile:
Thanks @clyra, this solved it for me after python3.8 venv upgrade
