So,
Let me preface this by saying this is probably not the best place to post this.
Anyway, some time back I put together an Audio/Visual system for my new house.
I’ve got the following:
- Sony KD-65X85K TV
- Yamaha TSR-700 AVR
- 6 Polk Audio ceiling speakers
- 1 Polk Audio center channel speaker
- Cerwin Vega floor mounted sub woofer.
The Yamaha is located in a closet off the garage about 30 feet (as the crow flies) from the remainder of the gear.
I had the builder install a plethora of wiring in the house, so I have a number of twisted pair and cat-6 lines available behind the TV. The A/V company refused to run an HDMI line and I now know why. He did provide a conduit in case additional lines were necessary.
I bought one of these (only 75’ long)
And ran it through the conduit and into the closet with the Yamaha. Interestingly enough iBirdie is no longer selling 75’ versions of this cord, which tells me something.
The cable “backfeeds” audio to the Yamaha via eArc.
Anyway. After about a year of usage a number of issues have emerged:
- The audio will get whiggy and drop out for a 1/2 second or so at irregular intervals. It will get really bad at which point I have to turn everything off and disconnect all the cables and the problem will go away for a while. I contacted the vendor about a warranty replacement and of course they didn’t respond. I did order a cable from another seller, but it didn’t work with my equipment and I returned it.
- My wife likes to listen to YouTube on the TV, which plays through the Yamaha. She will go out of the room and YT will do the “Are you there” stupidity and if she doesn’t respond, the TV will switch to “screen saver”. When it does this, it switches the audio from the Yamaha to the internal speakers. This completely flummoxes my wife and a majority of the time, I’ll come into the living room and she will ask why the sound is so bad… You have to manually switch the audio back to the sound system. And no, this behavoir cannot be switch off, as best as I can tell.
So, in order to slay all these demons, I’ve decided to go back to basics with this.
I’ve got a Toslink optical cable coming and will run that between the TV and the AVR.
What this means is I need to have a means of controlling the volume via control of the AVR.
I’ve got Home Assistant set up, with a have an Android TV Remote control gizmo built that works well, but my wife has indicated that she wants a “traditional” remote. Saying that ideally I would like a remote that HA could “interact” with.
So, I’m looking for some thoughts about physical remotes.
I’ve seen the Sofabaton remotes and they might be viable. Unfortunately Sofabaton doesn’t seem to be compatible with HA. I did a little looking around, and there seem to be a number of “back-door” approaches to conntectivity. I’m guessing Sofabaton has not opened their API.
If I used a Sofabaton (or something similar) am I going to need to do a IR repeater to get the signal from the TV to the closet with the AVRs to control the volume? It would be da’ bomb if I was able to provide this capability via a HA automation. The AVR’s have HA integrations. I can control the volume now via HA.
Anyway, would appreciate hearing your ideas about how to get all this buttoned together.
If this isn’t the right place to put this, please let me know.
cheers,
chris
