Availability: RAM limit for add-ons
Simple feature, add a memory limit to Homeassistant docker addons:
Some containers can have big memory usage (hi vscode) , it happens that by reaching the maximum memory the system is not responding anymore, and i have to restart manually or somehow get to ssh (take ages) and kill the process / container.
As all my house relies on Homeassistant’s availablilty it is a very annoying problem, especially since i also have another container that can cause this issue to happen (hi frigate) for a reason i haven’t identified yet.
A simple feature would be to add a config parameter in addon’s config.yaml like:
resources:
  memory: 4GB
Or add another way to allow like in a more common place like in the hass config.yaml so every user can also set the max size by addon (there are probably better solutions)
For now i have to run this command, every time hass is restarted:
docker update --memory 4G --memory-swap 4G addon_target
Thanks !
And amazing Job BTW
