I have again something I scratch my head about.
Maybe one of you can enlighten me what I am doing wrong.
I have this pretty simple Template Sensor:
# ---- Total Power Consumption ---- #
- sensor:
- name: "Total Power Consumption"
unit_of_measurement: W
device_class: power
state_class: measurement
state: >
{{ float(states('sensor.netz_total_power_consumed')) + float(states('sensor.pv_anlage_power'),0) - float(states('sensor.netz_total_power_returned'),0) }}
availability: >
{{ is_number(states('sensor.netz_total_power_consumed')) }}
However I get the following Error in the Logs:
Logger: homeassistant.components.template.template_entity
Source: components/template/template_entity.py:424
Integration: Template (documentation, issues)
First occurred: 02:01:37 (1 occurrences)
Last logged: 02:01:37
TemplateError('ValueError: Template error: float got invalid input 'unavailable' when rendering template '{{ float(states('sensor.netz_total_power_consumed')) + float(states('sensor.pv_anlage_power'),0) - float(states('sensor.netz_total_power_returned'),0) }}' but no default was specified') while processing template 'Template<template=({{ float(states('sensor.netz_total_power_consumed')) + float(states('sensor.pv_anlage_power'),0) - float(states('sensor.netz_total_power_returned'),0) }}) renders=25004>' for attribute '_attr_native_value' in entity 'sensor.total_power_consumption'
How can that be?
For 2 Values there is a default defined, the third value is checked via the availability template, that it actually contains a number.
So I would expect the Sensor to become unavailabel if sensor.netz_total_power_consumed got invalid input āunavailableā, but I would not expect this Error message.
Not all of your float functions have defaults, the first does not, and you are not checking the availability of all sensors used in the template. Try this:
state: >
{{ states('sensor.netz_total_power_consumed')|float(0) +
states('sensor.pv_anlage_power')|float(0) -
states('sensor.netz_total_power_returned')|float(0)
availability: >
{{ has_value('sensor.netz_total_power_consumed') and
has_value('sensor.pv_anlage_power') and
has_value('sensor.netz_total_power_returned')
When sensor.netz_total_power_consumed has a non-numeric Value (i.e. because Connection to the Sensor is lost) the Sensor should become unavailable. If any of the other two Sensors become unavailable it should instead just assume the value to be 0, hence the default in the float() function.
So the question remains:
Why am I getting this Error Message then?
Are you sure youāve reloaded the template entities (or restarted) since you last made changes? Iām unable to replicate your issue. I can only replicate the error if the availability template renders true. There are no errors when the the availability template renders false.
When I add not(ā¦) around the availability template then I get the error to show up. You might try that and see if there is any change. Make sure to clear the log so you are not seeing old errors.
ā¦but itās also probably good practice to make sure the state template renders correctly in all scenarios anywayā¦
Thereās a bug in has_value, where it doesnāt properly cause availability to update, a fix is coming whenever the PR is pushed through. has_value as a function (by some fluke) works correctly. However, when used as a filter, it does not work correctly.
If this is a trigger based template, the availability is not resolved prior to the state template.
If this is a non-trigger based template entity, then availability is always resolved first and you will not get this error. If you are getting this error, that means the template isnāt loaded into the system properly.
As a sidebar, the absence of a unique_id will cause YAML reloading to add an additional sensor instead of overwriting your original. Meaning you will fix your template but your old template will still error.
Make sure you restart to avoid that when making changes. And I advise you to add a unique_id so that you can reload properly without creating a new entity.
The Sensor above is pretty old and works reliably.
But as I am in the process of wheeding out Errors and Warnings and making my logic more robust and streamlined the Error message posted above sparked my interest for two reasons:
a) I dont understand why it is getting thrown in the first place.
b) the Setup of the Sensor in question is fairly common in my config, so this could affect others as well.
So yes, reloading changes / restarting Home Assistantā¦ I am accutely aware of that
@petro
Thanks! That is indeed shining more light on this.
It is a Template Sensor, so afaik it should get evaluated whenever one of its Values schanges and indeed the availability should be evaluated before the actual value template.
Now here it comesā¦ the time this Error was dropped does not allign to a restart of HA. So imho it SHOULD have been loaded properly into the system all the time.
But it might be (likely even) that the availability template {{ is_number(states('sensor.netz_total_power_consumed')) }} briefly became false at this point in time.
But to my understanding this should result in the state of this template sensor to transition to unavailable and NOT to the Error complaining about input 'unavailable'.
Am I right?
Or could it be, that there is a time gap between evaluating the availability template (input value still a number) and evaluating the state template (value has turned to āunavailableā in the meantime)?
EDIT: and thanks for the hint with the UniqueIDsā¦ I will look into this, but this likely turns into a major project giving all my Sensors unique IDs.
I cannot completely exclude that I reloaded the Config at that point in timeā¦
But can you confirm, that my expectation is correct:
Speaking about a Template Sensor, if the availability template evaluates to false, the state template will NOT be evaluated and instead the sensor will return āunavailableā?
If you reload template entities in yaml, entities without unique_id (Yours), will be duplicated. Youāll have the OLD template entity and the NEW template entity in your system at the same time. The old one would error, where the new one wouldnāt.
FWIW, expand misbehaves the same way; works as a function but fails as a filter (despite the documentationās claim that it can be used either way).
I reported it ages ago but nobody has been interested in fixing it. Works correctly as function or filter in the Template Editor but not when used in, for example, a Template Sensor.
To be clear, I havenāt installed 2023.9 so I havenāt confirmed if the bug still exists in the latest release.
I thought it was fixed awhile ago. @rccoleman put in a fix that didnāt make it through, when talking with him he alluded that someone else fixed it a different way.
