Is it possible to define an availability template that checks if the sensor is a number and is also greater than zero?
availability:
"{{ (states('sensor.emporiavue2_circuit_10_power')|is_number )}}"
Would something like this be correct?
availability:
"{{ (states('sensor.emporiavue2_circuit_10_power')|is_number and states('sensor.emporiavue2_circuit_10_power')|float > 0) }}"
123
(Taras)
2
The Jinja2 template is fine but the YAML needs minor corrections.
Like this:
availability: >
{{ states('sensor.emporiavue2_circuit_10_power')|is_number and states('sensor.emporiavue2_circuit_10_power')|float > 0 }}
Or like this:
availability: "{{ states('sensor.emporiavue2_circuit_10_power')|is_number and states('sensor.emporiavue2_circuit_10_power')|float > 0 }}"
Reference:
Important template rules
NOTE
For improved legibility, you may wish to consider doing this:
availability: >
{% set ecp = states('sensor.emporiavue2_circuit_10_power') %}
{{ ecp|is_number and ecp|float > 0 }}
tom_l
3
You don’t need the is_number test. Just use the float filter with a default of 0. If it is not a number the value will be replaced with zero:
availability: "{{ states('sensor.emporiavue2_circuit_10_power')|float(0) > 0 }}"
Actually I want the sensor to become unavailable if the number is not greater than 0. Wouldn’t it be better to prevent some errors?
tom_l
5
That’s what my template does.
If the source sensor is unavailable the value is set to zero → template = false → unavailable.
If the source sensor is < 0 → template = false → unavailable.
It prevents all errors you asked for.
