Availability template
Can someone tell please me how to apply the availability template to my situation?
Even with the examples I’ve seen, I keep getting errors.
I want to prevent my utility meters from showing wrong values ​​if the sensors are not available.
Like in this example.
  - platform: rest
    json_attributes:
    - waterflow
    - waterquantity
    resource: http://192.168.0.101/water.html
  - platform: rest
    json_attributes:
    - waterflow
    - waterquantity
    resource: http://192.168.0.100/water.html
template:
  - sensor:
      name: "meter_a quantity"
      state: "{{ ( state_attr('sensor.meter_a','waterquantity')|int) }}"
      state_class: "measurement"
      unit_of_measurement: "l"
  - sensor:
      name: "meter_b quantity"
      state: "{{ ( state_attr('sensor.meter_b', 'waterquantity')|int ) }}"
utility_meter:
  daily_meter_a:
    source: sensor.meter_a_quantity
    cycle: daily
  daily_meter_b:
   source: sensor.meter_b_quantity
   cycle: daily
Try this:
  - sensor:
      state: "{{ state_attr('sensor.meter_a','waterquantity')|int(-1) }}"
      availability: "{{ state_attr('sensor.meter_a','waterquantity')|int(-1) >= 0 }}"
Anything that can not be converted to an integer, like unavailable or unknown will be given the default value of -1.
The sensor will only be available if its state is 0 or greater.
Thank you Tom for the suggested solution.
I’ve entered it, but now I still need time to understand and learn from it.
Of course I still want to make an indicator that warns me when a sensor is unavailable too often or for too long.
