Available Python Options
Searching for options to run python in HA and came across pyscript. Is it still available because I can’t seem to find it in Integrations.
I also found a reference to Python Script but it seems limited for what I’m hoping to accomplish. The only other option I found was AppDeamon.
I’m hoping pyscript is still available… and if so, where can I find it?
Did you try googling home assistant pyscript?
it is a custom integration, so in HACS
Yes… and the information I found instructed: Under HACS → Integrations, select “+”, search for pyscript and install it.
I had to google HACS because I wasn’t familiar with it. Going to the HACS site and following the above instructions offers the following in the Integrations section:
hacs
Python Script is a listed option but that seems to differ from pyscript which isn’t listed as an option.
pyscript is an integration, as Francis pointed out.
Note that you can also plainly run python scripts through the shell_command built-in integration.
