Available update stops automation
Well, the title sums it up :slight_smile:
Whenever there’s an update available (updater triggers), all automation stops working. At least with Core updates. Automation continues to work after manual update. It has been like this since I started using HA (I think over a year ago), last incident was this morning. There was OS and Core update available, so my cars preheating didn’t trigger (or anything else that matters).
Hardware:
Raspberry 3B + Conbee II (problem exist with R4B also).
Is there setting/configuration, I’m not aware of? Is there a possibility to auto update Core too?
What errors do you see in your system and supervisor logs?
I updated the OS this morning, I can’t find logs earlier than that for some reason. After the major UI update late 2021, I haven’t dug deeper to settings. I can’t find anything any more, I had to google where to shutdown for maintenance, since it was not so easy anymore :smiley:
Where could I find earlier logs, Settings → Logs shows only after the update?
home-assistant.log.1
Do you have any automations that trigger on the state of the updater sensor?
Both log and log.1 start from yesterdays reboot. Logger is set to ‘critical’.
First line timestamp 2022-02-08 07:34:30
None of the automations are using updater as a trigger. I tried to make an automation to get notification to phone app when update available (to workaround this issue), but it didn’t work either and I have deleted that automation. All automations are primarily time/timer/sun event based, nothing fancy.
I have reset (fresh install HA) R3B at least two times, but I have restored a backup both times. That’s why I think this is a configuration or setting issue, since issue appears both R3B and R4B. With restored config on both.
Set it to info or debug.
Ok, thanks! I set it to ‘info’, let’s wait for some results.
