Am I missing something here? I used to have several zwave services and they no longer appear since upgrading to 0.28.2:
Is there something else I need to add so that I can heal the network and add devices again from HASS?
Interesting - I am seeing the same but hadn’t noticed.
Even more interesting is it appears to be back now?
Is this behavior expected?
Did you recently restart HA or issue a zwave/heal when you noticed all of them gone and renamed to zwave/x listings, or maybe recently added a new device when you noticed it? Maybe some action causes them to temporarily disappear when it is being performed and they come back once it is done.
I just checked mine and they are all there, and haven’t noticed the zwave/x format before, but I’ll definitely keep an eye out, and if it happens to me, hopefully I can find some correlation with an action I recently performed.
I did recently, yes which I had considered but I was unaware that it was effected by recently added devices as well (I have seen this before).
Appreciate the quick response, and I will too keep an eye out and pay closer attention.
I just checked and they were the same, then I reloaded and the proper names came back. I recall I have seen similar behavior before after a restart although I never tracked down the actual conditions or cause.
Interesting side note on the restart issue; it doesn’t seem to make a difference if you do the restart through the WebUI or using systemctl. After doing either one, restart will disappear unless you do a page refresh. And the behavior continues through subsequent restarts. If you do a reboot or start HASS from a stopped condition it’s fine.
