Avatto - curtain light switch (HA not recognized the light)
I succeed add the curtain but without the light
Anyone know what the issue?
i have the same problem , any one ? help ?
I have the same problem, works fine the curtain but switch light doesn’t show :frowning:
Maybe it’s because the type info in the device “Curtain switch by tuya”
See below my Curtain+2 Lights Avatto Tuya WIFI switch diagnostics.
I assume the problem is that in the Home Assistant the device can be recognized either as a curtain or as a switch.
In the diagnostics there lights parameters seem to be delivered:
 "Light_1": {
        "type": "Boolean",
        "value": {}
      "Light_2": {
        "type": "Boolean",
        "value": {}
However, they are probably ignored due to the device classification in Home Assistant as a Curtain.
Is any way to set it in the Home assistant as a double function device or splitting it somehow into 2 “virtual” devices?
My solution to overcome this issue till now was setting up the lights separately in the Local Tuya. However this is not stable - the entities are getting status “Unavailable” periodically with not a simple way to reauthenticate them .
Will appreciate your help.
  "home_assistant": {
    "installation_type": "Home Assistant OS",
    "version": "2023.5.4",
    "dev": false,
    "hassio": true,
    "virtualenv": false,
    "python_version": "3.10.11",
    "docker": true,
    "arch": "aarch64",
    "timezone": "Asia/Jerusalem",
    "os_name": "Linux",
    "os_version": "6.1.25",
    "supervisor": "2023.04.1",
    "host_os": "Home Assistant OS 10.1",
    "docker_version": "23.0.3",
    "chassis": "embedded",
    "run_as_root": true
  "custom_components": {
    "tuya_local": {
      "version": "2022.5.1",
      "requirements": [
        "pycryptodome~=3.17",
        "tinytuya==1.12.7"
    "hacs": {
      "version": "1.32.1",
      "requirements": [
        "aiogithubapi>=22.10.1"
    "androidtv_custom": {
      "version": "0.1.7",
      "requirements": [
        "adb-shell[async]==0.4.3",
        "androidtv[async]==0.0.70",
        "pure-python-adb[async]==0.3.0.dev0"
    "arpscan_tracker": {
      "version": "1.0.6",
      "requirements": []
    "localtuya": {
      "version": "5.0.0",
      "requirements": []
    "smartthinq_sensors": {
      "version": "0.31.6",
      "requirements": [
        "pycountry>=20.7.3",
        "xmltodict>=0.12.0",
        "charset_normalizer>=2.0.0"
  "integration_manifest": {
    "domain": "tuya",
    "name": "Tuya",
    "codeowners": [
      "@Tuya",
      "@zlinoliver",
      "@frenck"
    "config_flow": true,
    "dependencies": [
      "ffmpeg"
    "dhcp": [
        "macaddress": "105A17*"
        "macaddress": "10D561*"
        "macaddress": "1869D8*"
        "macaddress": "381F8D*"
        "macaddress": "508A06*"
        "macaddress": "68572D*"
        "macaddress": "708976*"
        "macaddress": "7CF666*"
        "macaddress": "84E342*"
        "macaddress": "D4A651*"
        "macaddress": "D81F12*"
    "documentation": "https://www.home-assistant.io/integrations/tuya",
    "integration_type": "hub",
    "iot_class": "cloud_push",
    "loggers": [
      "tuya_iot"
    "requirements": [
      "tuya-iot-py-sdk==0.6.6"
    "is_built_in": true
  "data": {
    "endpoint": "https://openapi.tuyaeu.com",
    "auth_type": 0,
    "country_code": "972",
    "app_type": "tuyaSmart",
    "mqtt_connected": true,
    "disabled_by": null,
    "disabled_polling": false,
    "name": "2Ron-Curtain+2gangs",
    "model": "",
    "category": "clkg",
    "product_id": "n76sxga6lyfujuac",
    "product_name": "Curtain switch",
    "online": true,
    "sub": false,
    "time_zone": "+03:00",
    "active_time": "2023-05-05T11:49:43+00:00",
    "create_time": "2023-03-24T09:50:09+00:00",
    "update_time": "2023-05-18T12:28:50+00:00",
    "function": {
      "control": {
        "type": "Enum",
        "value": {
          "range": [
            "open",
            "stop",
            "close",
            "continue"
      "percent_control": {
        "type": "Integer",
        "value": {
          "unit": "%",
          "min": 0,
          "max": 100,
          "scale": 0,
          "step": 10
      "cur_calibration": {
        "type": "Enum",
        "value": {
          "range": [
            "start",
            "end"
      "switch_backlight": {
        "type": "Boolean",
        "value": {}
      "control_back": {
        "type": "Enum",
        "value": {
          "range": [
            "forward",
            "back"
      "tr_timecon": {
        "type": "Integer",
        "value": {
          "unit": "s",
          "min": 10,
          "max": 120,
          "scale": 0,
          "step": 1
      "elec_machinery_mode": {
        "type": "Enum",
        "value": {
          "range": [
            "strong_power",
            "dry_contact"
      "Light_1": {
        "type": "Boolean",
        "value": {}
      "Light_2": {
        "type": "Boolean",
        "value": {}
      "countdown_L1": {
        "type": "Integer",
        "value": {
          "unit": "s",
          "min": 0,
          "max": 86400,
          "scale": 0,
          "step": 1
      "countdown_L2": {
        "type": "Integer",
        "value": {
          "unit": "s",
          "min": 0,
          "max": 86400,
          "scale": 0,
          "step": 1
    "status_range": {
      "control": {
        "type": "Enum",
        "value": {
          "range": [
            "open",
            "stop",
            "close",
            "continue"
        "type": "Integer",
        "value": {
          "unit": "%",
          "min": 0,
          "max": 100,
          "scale": 0,
          "step": 10
        "type": "Enum",
        "value": {
          "range": [
            "start",
            "end"
        "type": "Boolean",
        "value": {}
      "control_back": {
        "type": "Enum",
        "value": {
          "range": [
            "forward",
            "back"
      "tr_timecon": {
        "type": "Integer",
        "value": {
          "unit": "s",
          "min": 10,
          "max": 120,
          "scale": 0,
          "step": 1
        "type": "Enum",
        "value": {
          "range": [
            "strong_power",
            "dry_contact"
      "Light_1": {
        "type": "Boolean",
        "value": {}
      "Light_2": {
        "type": "Boolean",
        "value": {}
      "countdown_L1": {
        "type": "Integer",
        "value": {
          "unit": "s",
          "min": 0,
          "max": 86400,
          "scale": 0,
          "step": 1
      "countdown_L2": {
        "type": "Integer",
        "value": {
          "unit": "s",
          "min": 0,
          "max": 86400,
          "scale": 0,
          "step": 1
    "status": {
      "control": "stop",
      "percent_control": 0,
      "cur_calibration": "end",
      "switch_backlight": true,
      "control_back": "forward",
      "tr_timecon": 30,
      "elec_machinery_mode": "strong_power",
      "Light_1": false,
      "Light_2": false,
      "countdown_L1": 0,
      "countdown_L2": 0
    "home_assistant": {
      "name_by_user": null,
      "disabled": false,
      "entities": [
          "disabled": false,
          "entity_category": null,
          "device_class": null,
          "original_device_class": "curtain",
          "icon": null,
          "original_icon": null,
          "unit_of_measurement": null,
          "state": {
            "entity_id": "cover.2ron_curtain_2gangs_curtain",
            "state": "open",
            "attributes": {
              "current_position": 100,
              "device_class": "curtain",
              "friendly_name": "2Ron-Curtain+2gangs Curtain",
              "supported_features": 15
            "last_changed": "2023-05-25T04:37:37.121849+00:00",
            "last_updated": "2023-05-25T04:37:37.121849+00:00"
          "disabled": false,
          "entity_category": "config",
          "original_device_class": null,
          "icon": null,
          "state": {
            "entity_id": "light.2ron_curtain_2gangs_backlight",
            "state": "on",
            "attributes": {
              "supported_color_modes": [
                "onoff"
              "color_mode": "onoff",
              "friendly_name": "2Ron-Curtain+2gangs Backlight",
              "supported_features": 0
            "last_changed": "2023-05-25T04:37:37.134979+00:00",
            "last_updated": "2023-05-25T04:37:37.134979+00:00"
Have you find a solution ?
