AVATTO WT160 WiFi Intelligent Thermostat
Hello everyone!
Sorry if is already discussed but I can’t find any information.
Has anybody managed to connect the item to HA?
Help will be very much appreciated!
Yes, using Local Tuya integration.
I don’t like that thermostat at all because when I reset the router I have to reconnect to the AP using the thermostat GUI. The seller didn’t solved the issue. I have reverse engineered the thermostat and it uses the T5L ASIC and a DWIN display. The T5L ASIC contains a 8051 microcontroller
I have also 8 of these Avatto Thermostats model wt160.
I confirmed that from time to time or when the router resets itself (powersurge) I must connect manually to wifi each of them and is very annoying when I’m not home and I must control the settings remotely.
Anyone have a solution for this behavior ?
Thanks,
Cata
I can confirm that behaviour. After contacting the manufacturer and getting an update, the same behaviour.
No solution so far
