I am trying to calculate the average current a pump draws while it it is running. Currently I have the following entities already set up:
- sensor.sp_measured_current: Current meaurement from ESPHome
- binary_sensor.sump_pump_running: From code bellow
- sensor.sump_pump_running_24h_count: From code bellow
- sensor.sump_pump_running_24h_time: From code bellow
I would like to add sensor.sump_pump_running_24h_average that is the average over the last 24 hours of sensor.sp_measured_current while binary_sensor.sump_pump_running is on.
I have looked into the statistics and average sensors but they are averaging the entire 24 hours.
binary_sensor:
- platfrom: template
sensors:
sump_pump_running:
friendly_name: "Main Sump Pump Running"
value_template: '{{states("sensor.sp_measured_current") | float > 2}}'
- platfrom: history_stats
entity_id: binary_sensor.sump_pump_running
state: "on"
type: count
end: "{{ now() }}"
duration:
hours: 24
state: "on"
type: time
end: "{{ now() }}"
duration:
hours: 24
