Average sensor without zero value
Hey guys,
I’m measuring the COP of the heat pump with the following template sensor:
      - name: "COP with cooling"
        unit_of_measurement: "COP"
        state_class: measurement
        state: >-
          {% if
            state_attr('sensor.althermasensors','Operation Mode') in ('Heating', 'Cooling')
            and state_attr('sensor.althermasensors','Freeze Protection') == 'OFF'
            and state_attr('sensor.althermasensors','INV primary current (A)')  | float != 0
                state_attr('sensor.althermasensors','Flow sensor (l/min)') | float
                * 0.06
                * 1.16
                    state_attr('sensor.althermasensors','Leaving water temp. before BUH (R1T)') | float
                    - state_attr('sensor.althermasensors','Inlet water temp.(R4T)') | float
                * 230 | float
                / 1000
            | round(2)
            | abs
          {% else %} 0 {% endif %}
This works fine, but I want to know the average daily COP so I’ve created this:
- platform: statistics
  entity_id: sensor.cop_with_cooling
  state_characteristic: average_linear
  max_age:
    hours: 24
Only issue: This is getting me the average over the last 24 hours, including all the zero values.
How can I make a sensor that is giving me only the average daily value without any zero values?
How doese your solution look like?
