Trying this component now that it has been released but cannot get it to work with a dimmer that I have. I see the following error in my logs. Anyone else tried this yet?
File "/home/homeassistant/.homeassistant/deps/avion/__init__.py", line 38, in __init__
self.password = csrmesh.network_key(password)
AttributeError: 'module' object has no attribute 'network_key'
@mjg59 When you worked on this component, was there anything else that you needed to do to get it working? I am using a Raspberry Pi 3. I have manually typed my passphrase into the init.py file and it continues but then gives me another error around bluepy. Any help would be appreciated
Correct. I have the api key entered. Config below. Changed the MAC and api_key. Got these from the curl command listed in the component configuration. However, I have to remove the “| jq” to make this command work. I am able to get the passphrase from the output though and that is entered in the api_key section in the config below
light:
platform: avion
devices:
00:00:00:00:00:00:
api_key: <redacted>
Correct. I can manually enter the pass phrase in the file above where network key is listed but then it’s a completely different error. So I just reverted that file and waited for further assistance
Author of the csrmesh library here. This issue was a result of an API change made to the csrmesh library that python-avion depends on as of csrmesh 0.8 to add support for more than a single csrmesh device per network as well as to allow for communication with multiple classes of device. It looks like @mjg59 has updated his library to support the new API and I do not intend to make such radical API changes moving forwards unless there is a VERY pressing reason to do so. If you are still having trouble I should be able to help as well.
17-04-24 16:13:44 ERROR (MainThread) [homeassistant.components.light] Error while setting up platform avion
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 155, in _async_setup_platform
entity_platform.schedule_add_entities, discovery_info
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/light/avion.py", line 41, in setup_platform
light = AvionLight(device)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/light/avion.py", line 61, in __init__
self._switch = avion.avion(self._address, self._key)
I tried it again. I’m now on 0.46.0 and here is the error I receive now
2017-06-06 15:27:33 ERROR (MainThread) [homeassistant.components.light] Error while setting up platform avion
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 160, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
File "/usr/lib/python3.4/asyncio/tasks.py", line 372, in wait_for
return fut.result()
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/light/avion.py", line 62, in __init__
self._switch.connect()
File "/home/homeassistant/.homeassistant/deps/avion/__init__.py", line 40, in connect
self.device = btle.Peripheral(self.mac, addrType=btle.ADDR_TYPE_PUBLIC)
File "/home/homeassistant/.homeassistant/deps/bluepy/btle.py", line 318, in __init__
self.connect(deviceAddr, addrType, iface)
File "/home/homeassistant/.homeassistant/deps/bluepy/btle.py", line 353, in connect
self._startHelper()
File "/home/homeassistant/.homeassistant/deps/bluepy/btle.py", line 210, in _startHelper
universal_newlines=True)
File "/usr/lib/python3.4/subprocess.py", line 859, in __init__
restore_signals, start_new_session)
File "/usr/lib/python3.4/subprocess.py", line 1457, in _execute_child
raise child_exception_type(errno_num, err_msg)
OSError: [Errno 8] Exec format error
Can we just say that this plugin doesn’t work an a raspberry pi 3? Tried multiple times previously. Tried again after I noticed there was an update to the avi-on stuff with 0.49.0 and get different errors now.
2017-07-18 09:27:08 ERROR (MainThread) [homeassistant.components.light] Error while setting up platform avion
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 164, in _async_setup_platform
return fut.result()
import avion
File "/home/homeassistant/.homeassistant/deps/avion/__init__.py", line 12, in <module>
from bluepy import btle
File "/home/homeassistant/.homeassistant/deps/bluepy/__init__.py", line 2, in <module>
from . import btle
File "/home/homeassistant/.homeassistant/deps/bluepy/btle.py", line 711, in <module>
AssignedNumbers = _UUIDNameMap( get_json_uuid() )
File "/home/homeassistant/.homeassistant/deps/bluepy/btle.py", line 692, in __init__
for uuid in idList:
File "/home/homeassistant/.homeassistant/deps/bluepy/btle.py", line 707, in get_json_uuid
for number,cname,name in uuid_data[k]:
ValueError: need more than 2 values to unpack
