I would like to use different temperature sensors and window sensors to automate my AVM thermostats. But I am having a hard time to figure out where to start.
Eg. temp is below 20 and thermostat should heat until 20 is reached and keep the temperature. Not heat full every time temp sensor is 19 and heat full until 20. this will only drain the battery.
I can’t find any good information about this here
