joeFX
(Johann)
September 30, 2024, 11:10am
1
Hi guys,
I use the AVM FRITZ!Box Tools to control my guest Wi-Fi. Unfortunately, during the initial setup of the integration, I don’t have the option to disable the device tracker, which results in all devices known to the Fritzbox being automatically added to HA. In my case, I don’t need these devices. I also found some forum posts on this topic during my research, but no feature request. I can disable device tracking afterward, but the added devices cannot be deleted manually.
My specific suggestion would be to allow users to choose during the initial setup whether the device tracker should be activated or not, so that users can decide upfront whether devices should be added automatically or not.
Best regards,
Johann
rob1037
(Rob1037)
October 1, 2024, 8:17pm
2
Yes, please! That’s the reason I am not using the integration at the moment.
I feel like this request deserves a little push. I would love to use the integration in order to collect the various stats it exposes. But the device trackers are preventing me from using it. Would love to see that one come to life!
mib1185
(Michael)
May 3, 2025, 1:11pm
4
dev
← fritz/make-network-device-tracking-feature-optional
opened 01:09PM - 03 May 25 UTC
## Proposed change
This allows the user to disable the network device trackin… g feature, if they only want to monitor the Fritz!Box router or control the wifi state. This feature has been asked for multiple times, there is also [this feature request](https://community.home-assistant.io/t/avm-fritz-box-tools-add-possibility-to-disable-device-tracker-on-initial-setup/776956).
## Type of change
- [ ] Dependency upgrade
- [ ] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [x] New feature (which adds functionality to an existing integration)
- [ ] Deprecation (breaking change to happen in the future)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
- This PR fixes or closes issue: fixes #
- This PR is related to issue:
- Link to documentation pull request: https://github.com/home-assistant/home-assistant.io/pull/38863
- Link to developer documentation pull request:
- Link to frontend pull request:
## Checklist
- [x] The code change is tested and works locally.
- [x] Local tests pass. **Your PR cannot be merged unless tests pass**
- [x] There is no commented out code in this PR.
- [x] I have followed the [development checklist][dev-checklist]
- [x] I have followed the [perfect PR recommendations][perfect-pr]
- [x] The code has been formatted using Ruff (`ruff format homeassistant tests`)
- [x] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [x] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone+-status%3Afailure
[dev-checklist]: https://developers.home-assistant.io/docs/development_checklist/
[manifest-docs]: https://developers.home-assistant.io/docs/creating_integration_manifest/
[quality-scale]: https://developers.home-assistant.io/docs/integration_quality_scale_index/
[docs-repository]: https://github.com/home-assistant/home-assistant.io
[perfect-pr]: https://developers.home-assistant.io/docs/review-process/#creating-the-perfect-pr
UPDATE:
This PR got merged, so it will become available with 2025.6 (in June release )
Dude, you’re the real MVP, thanks a lot!
I did not expect such a quick reaction!
I sent you over a coffee
mib1185
(Michael)
May 4, 2025, 9:52am
6
Thanks for the beer … coffee
