I am still a beginner in the field, and have the following problem with the config:
Goal: On switch on the Hue Dimm switch should turn on the AVM outlet. (works)
Socket turns on for 10 min and then off for 4 min (currently 199x) (works).
When the Off button on the Hue Dimm switch is pressed, the outlet should turn off completely. (does not work)
Socket does turn off, but the loop continues.
What am I doing wrong???
Thanks in advance.
alias: Hue with AVM
description: ''
- device_id: XXXXXXXX
domain: hue
platform: device
type: remote_button_short_release
subtype: turn_on
- device_id: XXXXXXXXX
domain: hue
platform: device
subtype: turn_off
condition: []
- repeat:
count: '199'
sequence:
- type: turn_on
device_id: XXXXXXX
entity_id: switch.fritz_dect_210_1
domain: switch
- delay:
hours: 0
minutes: 10
seconds: 0
milliseconds: 0
- delay:
hours: 0
minutes: 4
seconds: 0
milliseconds: 0
- type: turn_off
device_id: XXXXXX
domain: switch
- wait_for_trigger:
- device_id: XXX
domain: hue
platform: device
subtype: turn_off
- type: turn_off
device_id: XXXX
domain: switch
mode: single
