I’m trying to force in my theme.yaml file the corner radius to 0px
whith this code
ha-card-border-radius: “0px”
with no results.
What is wrong?
Thankyou.
Stef
note: I’m running an old version of HA 2021.9.7.
whith this code
with no results.
What is wrong?
Thankyou.
Stef
Update!
My guess is, you need to set !important
on your css definition, otherwise it won’t work. I can’t say, if it works or not, as I can’t try and experiment with such an old version, too much has changed since then…sorry!
going to.
Rasp 5 already run a test version of my automations.
The version is old because I run a proprietary dietpi distribution , anyway it is scheduled!
Thankyou
That’s great, it really is an old version.
Have you tried the !important
in your css definition?
ehm, actually I use his file to switch to dark mode after sunset
Dark:
# Header:
app-header-background-color: rgb(23, 23, 23)
app-header-text-color: rgb(198, 203, 210)
# Main Interface Colors
<…omissis…>
# Cards
card-background-color: rgb(32, 33, 36)
ha-card-box-shadow: 1px 1px 5px 0px rgb(12, 12, 14)
paper-dialog-background-color: var(–card-background-color)
paper-listbox-background-color: var(–card-background-color)
paper-card-background-color: var(–card-background-color)
# Switches
switch-checked-button-color: rgb(255, 179, 26)
switch-checked-track-color: rgb(255, 179, 26)
<…etcetera…>
Light:
### Main Interface Colors ###
primary-color: “#395274”
<…etcetera…>
This is your definition,
try with
ha-card-border-radius: 0px !important
