I have a few automation scripts, that rely on zigbee/esphome devices. Sometimes, such a devices sadly becomes unavailable (especially battery powered zigbee devices …)
When these do become available, they either cause incorrect automation triggers (state whent from unavailable to ‘heating’ for example, where it was heating before already, or worse, the actuator wasn’t available, during the trigger, and now does something ‘old’.
Of course this can be fixed by writing tons of automations, e.g. ‘if devices becomes available again, check the state again, and see if you where supposed to be triggered on or off’, which basically means we have the normal script with the happy flow (e.g. a thermostat tells a boiler to turn on) but also an unhappy automation (the boiler checks uppon return what the thermostat state was).
Is there any way to avoid all of this, or is this just ‘life’ and the only way to deal with this is writing really good blueprints …?
I think the not_from is currently not available in the UI is it? (or it wasn’t on my phone)
But that only helps with half of the problem, and potentially introduces new ones. E.g. the state could be from: off OR from: idle or from: cool (potentially :p) or … well many other states.
The other half is that the actuator becomes available again, still means I have to write a unhappy flow automation …
