I just bought 2 Awox lights. These work fine in HA, together with 10 other lamps.
However, I also see them on my dashboard as a sensor.
Does anyone have an idea if this could be a wrong configuration?
Or does this happen more often and can I just make it invisible?
thanks
No body knowes?
So I recently got couple of Eglo/Awox lights myself and had the exact same question ![]()
So in case someone else stumbles upon this in the future I did some digging in the device info and based on the ZHA diagnostic data it seems the “Opening” sensor is mapped to cluster 0x0006, endpoint 1 - which is on/off cluster and as the name suggests it contains info whether the light is on or off…
Since this is basically duplicated with the “normal” light switch I would say just disable it unless you for some reason find it useful for automations or something like that.
