Awox Lightbulb ZHA + shelly l2.5 sometimes blinking
Hi newbie here,
I have AwoX 33943 Lightbulbs connected by ZHA and I’m having an issue that sometimes when I press the wall switch which is connected to the Shelly L2.5 set as momentary, bulbs starts blinking for like 1-2s and then turn off.
I know I could use detached mode to let bulbs always powered, but the circuit have another wall switch (without relay) which is connected as “staircase” not sure if it’s the right word and it stopped working when shelly was set to Detached. Another issue with detached would be when network would drop the switch would be dead.
I’m using default shelly FW.
Does anyone else have same problem or any solution?
