My current config is along this lines:
aws:
credentials:
- name: My AWS
aws_access_key_id: ...
aws_secret_access_key: ...
notify:
- service: lambda
region_name: ap-southeast-2
credential_name: "My AWS"
It’s the latest iteration. The doc is not perfectly clear about things, so I experimented.
All I seem to get when I send a notification is:
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 525, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 764, in _async_call_service_step
response_data = await self._async_run_long_action(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 727, in _async_run_long_action
return await long_task
File "/usr/src/homeassistant/homeassistant/core.py", line 2763, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2806, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/components/notify/legacy.py", line 275, in _async_notify_message_service
await self.async_send_message(**kwargs)
File "/usr/src/homeassistant/homeassistant/components/aws/notify.py", line 168, in async_send_message
await asyncio.gather(*tasks)
File "/usr/local/lib/python3.12/site-packages/aiobotocore/client.py", line 391, in _make_api_call
http, parsed_response = await self._make_request(
File "/usr/local/lib/python3.12/site-packages/aiobotocore/client.py", line 419, in _make_request
return await self._endpoint.make_request(
File "/usr/local/lib/python3.12/site-packages/aiobotocore/endpoint.py", line 98, in _send_request
request = await self.create_request(request_dict, operation_model)
File "/usr/local/lib/python3.12/site-packages/aiobotocore/endpoint.py", line 86, in create_request
await self._event_emitter.emit(
File "/usr/local/lib/python3.12/site-packages/aiobotocore/hooks.py", line 66, in _emit
response = await resolve_awaitable(handler(**kwargs))
File "/usr/local/lib/python3.12/site-packages/aiobotocore/_helpers.py", line 15, in resolve_awaitable
return await obj
File "/usr/local/lib/python3.12/site-packages/aiobotocore/signers.py", line 24, in handler
return await self.sign(operation_name, request)
File "/usr/local/lib/python3.12/site-packages/aiobotocore/signers.py", line 92, in sign
auth.add_auth(request)
File "/usr/local/lib/python3.12/site-packages/botocore/auth.py", line 418, in add_auth
raise NoCredentialsError()
botocore.exceptions.NoCredentialsError: Unable to locate credentials
