AWS SNS Credential Fail - Please Help
I get the following error when trying to send an SNS notification. What am I doing wrong here?
Config:
# aws notification
aws:
  notify:
    - service: sns
      aws_access_key_id: < access_key_id >
      aws_secret_access_key: < access_key_secret >
      region_name: us-east-1
Error:
2019-12-12 21:25:47 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: spotify_connect {'host': '192.168.1.30', 'port': 36713, 'hostname': 'b68393bb25cbda2-0.local.', 'properties': {'CPath': '/zc/0', 'VERSION': '1.0', 'Stack': 'SP'}}
2019-12-12 21:27:20 INFO (MainThread) [homeassistant.components.automation] Executing Basement Leak Alert
2019-12-12 21:27:20 INFO (MainThread) [homeassistant.helpers.script] Script Basement Leak Alert: Running script
2019-12-12 21:27:20 INFO (MainThread) [homeassistant.helpers.script] Script Basement Leak Alert: Executing step call service
2019-12-12 21:27:21 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.basement_leak_alert. Unknown error for call_service at pos 1:
  File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 443, in action
    await script_obj.async_run(variables, context)
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 190, in async_run
    await self._handle_action(action, variables, context)
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 273, in _handle_action
    await self._actions[_determine_action(action)](action, variables, context)
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 355, in _async_call_service
    context=context,
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 97, in async_call_from_config
    domain, service_name, service_data, blocking=blocking, context=context
  File "/usr/src/homeassistant/homeassistant/core.py", line 1235, in async_call
    await asyncio.shield(self._execute_service(handler, service_call))
  File "/usr/src/homeassistant/homeassistant/core.py", line 1260, in _execute_service
    await handler.func(service_call)
  File "/usr/src/homeassistant/homeassistant/components/notify/__init__.py", line 120, in async_notify_message
    await notify_service.async_send_message(**kwargs)
  File "/usr/src/homeassistant/homeassistant/components/aws/notify.py", line 197, in async_send_message
    await asyncio.gather(*tasks)
  File "/usr/local/lib/python3.7/site-packages/aiobotocore/client.py", line 92, in _make_api_call
    operation_model, request_dict, request_context)
  File "/usr/local/lib/python3.7/site-packages/aiobotocore/client.py", line 113, in _make_request
    request_dict)
  File "/usr/local/lib/python3.7/site-packages/aiobotocore/endpoint.py", line 226, in _send_request
    request = self.create_request(request_dict, operation_model)
  File "/usr/local/lib/python3.7/site-packages/botocore/endpoint.py", line 116, in create_request
    operation_name=operation_model.name)
  File "/usr/local/lib/python3.7/site-packages/botocore/hooks.py", line 356, in emit
    return self._emitter.emit(aliased_event_name, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/botocore/hooks.py", line 228, in emit
    return self._emit(event_name, kwargs)
  File "/usr/local/lib/python3.7/site-packages/botocore/hooks.py", line 211, in _emit
    response = handler(**kwargs)
  File "/usr/local/lib/python3.7/site-packages/botocore/signers.py", line 90, in handler
    return self.sign(operation_name, request)
  File "/usr/local/lib/python3.7/site-packages/botocore/signers.py", line 157, in sign
    auth.add_auth(request)
  File "/usr/local/lib/python3.7/site-packages/botocore/auth.py", line 357, in add_auth
    raise NoCredentialsError
botocore.exceptions.NoCredentialsError: Unable to locate credentials
I’m also running into a similar issue, except seems I have all my stuff setup correctly. (It’s worth noting that several HA versions back, this used to work fine, but I think they had changed aws integrations in past year or so)
in configuration.yaml:
notify:
 - name: aws_sns_ha_notify
   platform: group
   services:
    - service: sns_us_west_2
        target: "arn:aws:sns:us-west-2:1234_REDACTED:ha_notify_email"
aws:
  credentials:
    - name: test profile
      aws_access_key_id: "AKID......REDACTED"
      aws_secret_access_key: !secret aws_secret_access_key
  notify:
    - service: sns
      credential_name: test profile
      region_name: us-west-2
in log:
Jan 01 15:33:54 spire docker[7839]: 2020-01-01 15:33:54 INFO (MainThread) [homeassistant.components.alert] Alerting: Door 2 opened.
Jan 01 15:33:55 spire docker[7839]: 2020-01-01 15:33:55 ERROR (MainThread) [homeassistant.core] Error executing service <ServiceCall notify.sns_us_west_2 (c:6bad5c6498d4479a838725f8b2a1c611): message=Template("Door 2 opened."), target=['arn:aws:sns:us-west-2:1234_REDACTED:ha_notify_email']>
Jan 01 15:33:55 spire docker[7839]: Traceback (most recent call last):
Jan 01 15:33:55 spire docker[7839]:   File "/usr/src/homeassistant/homeassistant/core.py", line 1243, in _safe_execute
Jan 01 15:33:55 spire docker[7839]:     await self._execute_service(handler, service_call)
Jan 01 15:33:55 spire docker[7839]:   File "/usr/src/homeassistant/homeassistant/core.py", line 1260, in _execute_service
Jan 01 15:33:55 spire docker[7839]:     await handler.func(service_call)
Jan 01 15:33:55 spire docker[7839]:   File "/usr/src/homeassistant/homeassistant/components/notify/__init__.py", line 120, in async_notify_message
Jan 01 15:33:55 spire docker[7839]:     await notify_service.async_send_message(**kwargs)
Jan 01 15:33:55 spire docker[7839]:   File "/usr/src/homeassistant/homeassistant/components/aws/notify.py", line 197, in async_send_message
Jan 01 15:33:55 spire docker[7839]:     await asyncio.gather(*tasks)
Jan 01 15:33:55 spire docker[7839]:   File "/usr/local/lib/python3.7/site-packages/aiobotocore/client.py", line 92, in _make_api_call
Jan 01 15:33:55 spire docker[7839]:     operation_model, request_dict, request_context)
Jan 01 15:33:55 spire docker[7839]:   File "/usr/local/lib/python3.7/site-packages/aiobotocore/client.py", line 113, in _make_request
Jan 01 15:33:55 spire docker[7839]:     request_dict)
Jan 01 15:33:55 spire docker[7839]:   File "/usr/local/lib/python3.7/site-packages/aiobotocore/endpoint.py", line 226, in _send_request
Jan 01 15:33:55 spire docker[7839]:     request = self.create_request(request_dict, operation_model)
Jan 01 15:33:55 spire docker[7839]:   File "/usr/local/lib/python3.7/site-packages/botocore/endpoint.py", line 116, in create_request
Jan 01 15:33:55 spire docker[7839]:     operation_name=operation_model.name)
Jan 01 15:33:55 spire docker[7839]:   File "/usr/local/lib/python3.7/site-packages/botocore/hooks.py", line 356, in emit
Jan 01 15:33:55 spire docker[7839]:     return self._emitter.emit(aliased_event_name, **kwargs)
Jan 01 15:33:55 spire docker[7839]:   File "/usr/local/lib/python3.7/site-packages/botocore/hooks.py", line 228, in emit
Jan 01 15:33:55 spire docker[7839]:     return self._emit(event_name, kwargs)
Jan 01 15:33:55 spire docker[7839]:   File "/usr/local/lib/python3.7/site-packages/botocore/hooks.py", line 211, in _emit
Jan 01 15:33:55 spire docker[7839]:     response = handler(**kwargs)
Jan 01 15:33:55 spire docker[7839]:   File "/usr/local/lib/python3.7/site-packages/botocore/signers.py", line 90, in handler
Jan 01 15:33:55 spire docker[7839]:     return self.sign(operation_name, request)
Jan 01 15:33:55 spire docker[7839]:   File "/usr/local/lib/python3.7/site-packages/botocore/signers.py", line 157, in sign
Jan 01 15:33:55 spire docker[7839]:     auth.add_auth(request)
Jan 01 15:33:55 spire docker[7839]:   File "/usr/local/lib/python3.7/site-packages/botocore/auth.py", line 357, in add_auth
Jan 01 15:33:55 spire docker[7839]:     raise NoCredentialsError
Jan 01 15:33:55 spire docker[7839]: botocore.exceptions.NoCredentialsError: Unable to locate credentials
maybe worth noting that I do not have any ~/.aws/credentials files setup - this should work fine defining them entirely in ha configs.
maybe related:
