⚽️ AWTRIX - AWTRIX - Scoreboard With Last Play
:soccer: AWTRIX - Scoreboard
Importar Blueprint
This blueprint displays real-time football (soccer) match scores on your AWTRIX 3 device using data from the TeamTracker integration. It’s perfect for fans who want to follow their favorite team’s match live with a clear and colorful scoreboard on their AWTRIX LED display or clock.
The display updates automatically when the game starts, scores change, halftime is reached, or a new play is detected. Team colors are dynamically applied based on whether your team is playing at home or away.
Requirements:
  • AWTRIX 3 device with MQTT integration.
  • A team sensor from the teamtracker integration.
Customizable:
  • AWTRIX app name (must be unique).
  • Message display duration.
  • Your favorite team sensor.
To thank: AWTRIX 3 Hank_the_Tank
Awtrix-2
blueprint:
  name: ⚽️ AWTRIX - Marcadores
  author: matbott
  domain: automation
  input:
    awtrix:
      description: Select the Awtrix 3
      selector:
        device:
          integration: mqtt
          manufacturer: Blueforcer
          model: AWTRIX 3
          multiple: true
    appname:
      name: Awtrix Application name
      description: This is the app name listed in the MQTT topic - it should be unique
      default: app_futbol
      selector:
        text: {}
    message_duration:
      name: Message Duration ⏱️
      description: How long should the message remain on the screen (in seconds).
      selector:
        number:
          min: 0.0
          max: 300.0
          unit_of_measurement: sec
          step: 1.0
          mode: slider
      default: 15
    my_sensor:
      description: Select your Team Sensor
      selector:
        entity:
          filter:
            - integration: teamtracker
          multiple: false
  source_url: https://github.com/matbott/ha/blob/main/blueprint_marcadores.yaml
variables:
  device_ids: !input awtrix
  devices:
    "{% macro get_device(device_id) %}\n  {{ states((device_entities(device_id)
    | select('search','device_topic') | list)[0] | default('unknown')) }}\n{% endmacro
    %} {% set ns = namespace(devices=[]) %} {% for device_id in device_ids %}\n  {%
    set device=get_device(device_id)|replace(' ','')|replace('\\n','') %}\n  {% set
    ns.devices = ns.devices + [ device ] %}\n{% endfor %} {{ ns.devices | reject('match','unavailable|unknown')
    | list }}"
  appname: !input appname
  my_sensor: !input my_sensor
  message_duration: !input message_duration
  homegame: "{% if state_attr(my_sensor, 'team_homeaway') == 'home' -%} True {%
    else -%} False {% endif %}"
  color_home_team_1:
    "{{ state_attr(my_sensor, 'team_colors')[0]  if homegame else
    state_attr(my_sensor, 'opponent_colors')[0]  }}"
  color_home_team_2:
    "{{ state_attr(my_sensor, 'team_colors')[1]  if homegame else
    state_attr(my_sensor, 'opponent_colors')[1]  }}"
  color_away_team_1:
    "{{ state_attr(my_sensor, 'opponent_colors')[0]  if homegame
    else state_attr(my_sensor, 'team_colors')[0]  }}"
  color_away_team_2:
    "{{ state_attr(my_sensor, 'opponent_colors')[1]  if homegame
    else state_attr(my_sensor, 'team_colors')[1]  }}"
  home_team_score:
    "{{ state_attr(my_sensor, 'team_score') if homegame else state_attr(my_sensor,
    'opponent_score') }}"
  away_team_score: "{{ state_attr(my_sensor, 'opponent_score') if homegame else
    state_attr(my_sensor, 'team_score') }}"
  payload_switch: "{\n  \"name\" : \"{{ appname }}\"\n}"
  play_text: >-
    {% set last_play = state_attr(my_sensor, 'last_play') %}
      {% set play_text = '' %}
      {% if last_play is string and ("'" in last_play) %}
        {% set last_index = last_play.rfind("'") %}
        {% set minute = last_play[last_index - 2:last_index + 1] %}
        {% set play_text = last_play[last_index - 2:] | trim %}
      {% else %}
        {% set play_text = last_play %}
      {% endif %}
  scoreBoard:
    "{\n  \"text\": \"     {{ state_attr(my_sensor, 'team_abbr') }} {{ home_team_score }}-{{ away_team_score }} {{ state_attr(my_sensor, 'opponent_abbr') }} - {{ state_attr(my_sensor, 'clock') }} | {{ play_text }}\",\n  \"draw\":[
    \n    {\"df\":[0,1,8,2,\"{{ color_home_team_1 }}\"]},\n    {\"df\":[1,3,6,5,\"{{
    color_home_team_1 }}\"]},\n    {\"dl\":[3,0,4,0,\"{{ color_home_team_1 }}\"]},\n
    \   {\"dl\":[2,2,2,7,\"{{ color_home_team_2 }}\"]},\n    {\"dl\":[5,2,5,7,\"{{
    color_home_team_2 }}\"]},\n    {\"df\":[24,1,8,2,\"{{ color_away_team_1 }}\"]},\n
    \   {\"df\":[25,3,6,5,\"{{ color_away_team_1 }}\"]},\n    {\"dl\":[27,0,28,0,\"{{
    color_away_team_1 }}\"]},\n    {\"dl\":[26,2,26,7,\"{{ color_away_team_2 }}\"]},\n
    \   {\"dl\":[29,2,29,7,\"{{ color_away_team_2 }}\"]}    \n  ], \n  \"duration\":
    {{ message_duration }},\n  \"background\": \"#006c28\"\n}"
  - platform: state
    entity_id: !input my_sensor
    to: "IN"
  - platform: state
    to:
      - "PRE"
      - "POST"
      - "NOT_FOUND"
  - platform: state
    attribute: team_score
  - platform: state
    attribute: opponent_score
  - platform: state
    attribute: quarter
    to: "2"
  - platform: state
    attribute: last_play
  - platform: state
    attribute: clock
    to: "MT"
condition: []
  - repeat:
      for_each: "{{ devices }}"
      sequence:
        - choose:
            - conditions:
                - condition: trigger
                  id:
                    - gameStart
                    - scoreChangeHome
                    - scoreChangeOpponent
                    - halftime
                    - lastPlayChange
                    - clock
                - condition: state
                  state: IN
              sequence:
                - service: mqtt.publish
                    qos: 0
                    retain: false
                    topic: "{{ repeat.item }}/custom/{{ appname }}"
                    payload: "{{ scoreBoard }}"
                    qos: 0
                    retain: false
                    topic: "{{ repeat.item }}/switch"
                    payload: "{{ payload_switch }}"
            - conditions:
                  id:
                    - noGame
              sequence:
                    qos: 0
                    retain: false
                    payload: "{}"
mode: restart
“The new version 1.1v improves the last_play filter for better visualization”
Update blueprint v1.3
Source not found?
Sorry, I’ll leave the direct link.
Great work, thanks
