Awtrix (clock) notification [Custom Component]
will add as you request
service: awtrix.awtrix_bedroom_weather_app
  weather: weather.forecast_home
  outside_temperature: sensor.easyweatherv1_6_4_outdoor_temperature
  home_temperature: sensor.home_temperature
  sun: sun.sun
  moon: sensor.moon_phase
    weather_sun:
      rainbow: true
      repeat: 3
      duration: 10
so:
key data
then
name of app (weather, weather_night, weather_sun, weather_home)
then any config keys from awtrix light
will add
    sun_event_minute_threshold: 180
    weather_sun:
      rainbow: true
      repeat: 3
      duration: 10
ver 20240317.01
Perfect, great Job!!! Works right the way you wrote. Now it’s perfect for me :+1:
where does this code go to create an app?
Manually here http://homeassistant.local:8123/developer-tools/service
create automation here
http://homeassistant.local:8123/config/automation
example
alias: "AWTRIX: weather"
description: ""
  - platform: time_pattern
    minutes: /5
condition: []
  - service: awtrix.awtrix_bedroom_weather_app
      sun: sun.sun
mode: single
NB: do not forget to set own entities!
There is a little problem with setting the config keys in the weather_sun app. When set, it would add an empty app when the threshold to sunrise or sunset is not reached with only the config key of awtrix, looks like this in mqtt:
(I have the key for duration set). Seems the custom_component should check if threshold is not reached and then do not add the config keys of awtrix.
oops! on it!
fixed. pushed
Thank you so much for reporting.
Tested a whole day in homeoffice, no glitches and the mqtt messages looks fine also:
Thank you so much for programming!
ver 20240320.01
service: awtrix.awtrix_bedroom_rtttl
 rtttl: "two_short:d=4,o=5,b=100:16e6,16e6"
service: awtrix.awtrix_bedroom_sound
 sound: beep
Hold notification
service: notify.awtrix_bedroom
  message: "Hello!"
    hold: true
Dismiss hold notification
  message: ""
How to remove weather_night app from mqtt?
I disable the moon option in my automation but it stay on my awtrix screen.
fixed! please update
It works now thanks
It would be nice if the weather app shows temperature forecast like a graph instead of a coloured line.
For example weather icon + current temperature + forecast temperature as a graph.
:slight_smile:
awtrix (16)
is it OK for you?
Yes, looks cool.
Is it a new separate app ?
Maybe a thermometer icon before the graph
  1. I won’t draw all manually. API can’t draw icon right side.
  2. bar look ugly
  3. redraw as graph line also looks ugly
  4. awtrix (17)
    IMHO uninformative
do not pay attention on red corner - it’s air alert in the city. f*cking russian.
