Home Assistant publishes an icon property which is basically battery_80 or battery_charging_80 - so the easy mode was to name the icons accordingly so they can be loaded by the blueprint.
Thank you for this, it works great except for the pushIcon but I noticed that you put it twice in the payload, the last one being “pushIcon”:1. I think the one with the variable is just ignored.
First of all thanks for the Blueprint,
basically it works - but somehow i don´t get how to implement the Icons in front of the Text.
I downloaded them and but them into AWTRIX - buy you mentioned to change the icon names - but i didn´t see somehow the names associated. The only i see is “Battery_sensor.attributes” ?
Thanks for this sharing !
I successfully set it in my HA, now for me the question is : how can I optmize, modify some parameters, as such as the frequency of notification, the treshold to enable the notification etc. I am not familiar with the automations/YAML…
