You need to create a toggle helper for this automation,
It functions like a switch to turn your notifications on or off.
This will activate on your Awtrix Display every 5 minutes with your text and battery percentage.
You can customize your text with colors, or even display rainbow colors.
For the background, you can add an icon and choose its behavior, control the text display behavior, and select the duration time for the text.
The icon used in this blueprint is “1095” which you can download from your Awtrix devices.
blueprint:
name: Awtrix Phone Battery Notification
description: Phone Charging indicator on Awtrix Display.
domain: automation
author: Sevag
input:
awtrix_light:
description: Select the target Awtrix display.
selector:
device:
filter:
- integration: mqtt
manufacturer: Blueforcer
model: AWTRIX 3
mobile_battery:
name: Phone or device
description: select your Phone Battery.
selector:
entity:
filter:
- integration: mobile_app
device_class:
- battery
- state
multiple: false
toggle_on:
description: Select the Toggle Helper that will toggle the automation on or off.
selector:
entity:
domain: input_boolean
message_text:
description: Enter the notification text.
default: "My Phone Battery is"
icon_in:
description: Enter the Icon Name or ID of the icon.
selector:
text:
default: ""
push_icon:
description: Icon behavior
selector:
select:
options:
- label: "Icon doesn't move"
value: "0"
- label: "Icon moves with text and will not appear again"
value: "1"
- label: "Icon moves with text but appears again when the text starts"
value: "2"
mode: dropdown
default: "2"
duration:
name: Duration (in seconds)
description: Sets how long the app should be displayed unit is seconds.
default: "10"
text_case:
description: Select how you would like your text to display.
selector:
select:
options:
- label: "Use global setting"
value: "0"
- label: "Force Uppercase"
value: "1"
- label: "Show as you entered it"
value: "2"
mode: dropdown
default: "2"
background_color:
description: Select the Background color
selector:
color_rgb:
default: [0, 0, 0]
text_color:
description: Select the Text color.
selector:
color_rgb:
default: [255, 255, 255]
show_rainbow:
description: Should the notification be shown in Rainbow colors?
selector:
boolean:
default: false
mode: queued
- platform: time_pattern
minutes: /5
variables:
device_id: !input awtrix_light
awtrix_light: "{{ iif( device_attr(device_id, 'name_by_user') != none, device_attr(device_id, 'name_by_user'), device_attr(device_id, 'name') ) }}"
my_sensor: !input mobile_battery
message_text: !input message_text
all_text: >
{{ message_text }}{{ ' ' }}{{states(my_sensor, "state" , "unit_of_measurement" )}}
duration_on: !input duration
show_rainbow: !input show_rainbow
push_icon: !input push_icon
icon_in: !input icon_in
background_color: !input background_color
text_color: !input text_color
text_case: !input text_case
toggle_con: !input toggle_on
condition:
- condition: state
entity_id: !input toggle_on
state: "on"
service: mqtt.publish
qos: 0
retain: false
topic: "{{awtrix_light}}/notify"
payload: |-
"text": "{{ all_text }}",
"icon": "{{ icon_in }}",
"background": {{ background_color }},
"color": {{ text_color }},
"textCase": {{ text_case }},
"pushIcon": {{ push_icon }},
"rainbow": {{ iif(show_rainbow, "true", "false") }},
"duration": {{ duration_on }}
