After updating HA, it seems 5 of 6 of my AXIS cameras has stopped working with the integration.
This is from the error log.
As said, i have 6 cameras of various models, only one works.
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 504, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/axis/__init__.py", line 21, in async_setup_entry
api = await get_axis_device(hass, config_entry.data)
File "/usr/src/homeassistant/homeassistant/components/axis/device.py", line 261, in get_axis_device
await device.vapix.initialize()
File "/usr/local/lib/python3.12/site-packages/axis/vapix/vapix.py", line 146, in initialize
await self.initialize_applications()
File "/usr/local/lib/python3.12/site-packages/axis/vapix/vapix.py", line 207, in initialize_applications
await self.applications.update()
File "/usr/local/lib/python3.12/site-packages/axis/vapix/interfaces/api_handler.py", line 126, in update
obj_ids = await self._update()
File "/usr/local/lib/python3.12/site-packages/axis/vapix/interfaces/api_handler.py", line 115, in _update
objects = await self._api_request()
File "/usr/local/lib/python3.12/site-packages/axis/vapix/interfaces/applications/applications.py", line 35, in _api_request
return await self.get_api_list()
File "/usr/local/lib/python3.12/site-packages/axis/vapix/interfaces/applications/applications.py", line 40, in get_api_list
response = ListApplicationsResponse.decode(bytes_data)
File "/usr/local/lib/python3.12/site-packages/axis/vapix/models/applications/application.py", line 168, in decode
return cls(data=Application.decode_to_dict(apps))
File "/usr/local/lib/python3.12/site-packages/axis/vapix/models/api.py", line 29, in decode_to_dict
return {v.id: v for v in cls.decode_to_list(data)}
File "/usr/local/lib/python3.12/site-packages/axis/vapix/models/api.py", line 24, in decode_to_list
return [cls.decode(data) for data in data_list]
File "/usr/local/lib/python3.12/site-packages/axis/vapix/models/applications/application.py", line 134, in decode
configuration_page=data["ConfigurationPage"],
KeyError: 'ConfigurationPage'
PS. All cameras are online in my DVR and i have made no changed to those.
2024-03-08 21:55:39.341 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry XYZ-Camera for axis
File "/usr/local/lib/python3.12/site-packages/axis/vapix/vapix.py", line 144, in initialize
await self.initialize_api_discovery()
File "/usr/local/lib/python3.12/site-packages/axis/vapix/vapix.py", line 162, in initialize_api_discovery
await asyncio.gather(*[api.update() for api in apis if api.supported])
File "/usr/local/lib/python3.12/site-packages/axis/vapix/interfaces/port_management.py", line 31, in _api_request
return await self.get_ports()
File "/usr/local/lib/python3.12/site-packages/axis/vapix/interfaces/port_management.py", line 36, in get_ports
return GetPortsResponse.decode(bytes_data).data
File "/usr/local/lib/python3.12/site-packages/axis/vapix/models/port_management.py", line 221, in decode
data=Port.decode_to_dict(data["data"]["items"]),
KeyError: 'items'
Yeah, reading through the other threads, Kane610 appears to have a fix in the works. Given that HA sometimes has releases every week, hopefully we’ll see an update soon.
Same here, glad I’ve found this threat. So not my fault, had some router issues here (changed this Netgear Orbis router eventually) and thought may be that was the problem…
