Dear All,
Since I have started working with Home Assistant, I started with a small project to automate the Azan (Muslim Prayer Call) with my Nest Mini. I have done my research and first tried to run the configuration available on the forum. Unfortunately it did not worked for me at all. Then in the discord group someone told me to add integration and then automate. I did that but still it is not running.
Whenever I reload the integration it start playing the Azan but it is not as per the time itâs like randomly I tried to reload the integration and it started playing the azan. I request if anyone can help. I will be grateful.
The automation code I found on the forum is as follows:
- id: '2020042901'
alias: Adhan Fajr
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M,
%Y-%m-%d")) == as_timestamp(strptime(states("sensor.fajr_prayer"), "%Y-%m-%dT%H:%M:%S"))
condition: []
- data:
volume_level: 0.3
entity_id: media_player.living_room_speaker
service: media_player.volume_set
entity_id:
- media_player.living_room_speaker
- service: media_player.play_media
media_content_id: http://x.x.x.x:8123/local/Mishary_Rashid_Fajr.mp4
media_content_type: audio/mp4
- delay: 00:00:00
- id: '2020042902'
alias: Adhan Dhuhr and Asr
%Y-%m-%d")) == as_timestamp(strptime(states("sensor.dhuhr_prayer"), "%Y-%m-%dT%H:%M:%S"))
%Y-%m-%d")) == as_timestamp(strptime(states("sensor.asr_prayer"), "%Y-%m-%dT%H:%M:%S"))
condition: []
- data:
volume_level: 0.4
- data:
media_content_id: http://x.x.x.x:8123/local/Mishary_Rashid_Azan.mp4
media_content_type: video/mp4
- delay: 00:00:00
mode: single
- id: '151769301093'
alias: Adhan Maghrib and Isha
%Y-%m-%d")) == as_timestamp(strptime(states("sensor.maghrib_prayer"), "%Y-%m-%dT%H:%M:%S"))
%Y-%m-%d")) == as_timestamp(strptime(states("sensor.isha_prayer"), "%Y-%m-%dT%H:%M:%S"))-1800
condition: []
- data:
volume_level: 0.4
device_id: b19748c5c11121ca67ade94f9ce4ea12
- data:
- delay: 00:00:00
mode: single
This Automation works manually but its automation it should work automatically please help if someone can.
Big thank you.
