Baby feeding script tracker
Hi
I want to setup two scripts which i will associate with a google home shortcut/routine.
The first script will store the current time / date and will happen when i feed the baby.
The second strip will tell me how long since the last feed.
Unfortunately this is well beyound my ability, however I’ve started things of as follows, and I’m hopeful that someone will fix it up for me.
input_text:
  hours_since_last_feed:
    name: Time since last feed
input_datetime:
  last_feed:
    name: "When Alex was last fed"
    has_date: true
    has_time: true
script:
  set_last_feed:
    sequence:
      - service: input_datetime.set_datetime
        entity_id: input_datetime.last_feed
        data_template:
          datetime: "{{ now().strftime('%Y-%m-%d %H:%M:%S') }}"
  when_last_feed:
    sequence:
      # compare current time to input_datetime.set_datetime
      # store result as input_text.hours_since_last_feed
      # would be cool if it could round to say 2 hours / 2 and a quater / 2 and a half / 2 and three quaters.
      - service: tts.google_translate_say
        data_template:
          message: "Alex was last fed {{states('input_text.hours_since_last_feed')}} hours ago."
          cache: false
          message: >
              ((as_timestamp(now()) - as_timestamp(states('input_datetime.last_feed')))/3600)|round(1)
            }} hours ago.
that works thank you!
