Background Picture
Suggest you to use manuals written by humans (there are plenty of them) and less depend on chatgpt.
Cannot give you a proper command.
What kind of installation do you use?
Using “sudo” allows you to execute commands from root.
Are you using HassOS ? If yes - sorry, cannot help… this is some kind of limited version of *nix system…
Hi Nick.
Thanks for the response. Where do I edit the background for this particular Overview Page? That has been the crux of my question all along.
Can you open a “edit view” (or whatever it is titled) dialog for this view?
Does it have any mentioning of a background?
Right hand top: that pencil
I Nick
I think you and I covered this off already and found that it couldn’t be done from there.
I can open “Raw Config” from the hamburger menu, however I can’t find the picture.
Well, it is a mystery. The background is not set in raw yaml editor - but is shown.
Then try grepping that jpg.
BTW, just in case - clear your browser cache.
At the top of your board click on the pencil on the right.
Then, when in edit mode click the pencil near your home tab
Capture d’écran 2024-11-08 à 00.44.26
In the pop up, go to “Background tab”
Can you confirm there is no background configured there for the specific home tab of your dashboard ?
I agree with @Ildar_Gabdullin , it is super weird you see nothing related in raw yaml config … what kind of installation do you have ? HAOS, supervised , anything else ? Do you have an ssh / console access to home assistant config files ?
Already asked this, OP seems to miss it…
Sorry for the delay.
I hope this answeres your question and thanks for the help.
Michael, have you seen/read/followed Nicolas his explanation from 2 days ago?
Hello. I just followed what I thought was his instructions and the main view - everything from the first tab is gone.I hope I can restore via a backup. The term “Delete View” is a bit misleading, especially when I’ve selected “Background” to work with. I would have thought that that meant “delete the picture” not the entire tab and all it’s contents.
So, where are you now with your original request/issue?
umm… I busy trying to rebuild the main page of my home assistant; the one that tells me the weather, the garbage pickup, the sunrise and sunset etc. Good news is the picture is gone.
Phew, that was a tough delivery…
So now you can mark this thread as solved by selecting the answer that helped you solve it.
Done. Issue solved. Thanks Nick for the help and followup.
Strange though to mark your own post with repetition from what @nok posted as the solution… :face_with_raised_eyebrow:
Besides, thanking only one person (although Nick was really the most active) and ignoring others does not look good.
Well, pretty sure this was the issue then.
Sorry you lost your dashboard while trying to find this tab …
Glad the issue is solved tho
Cheers,
Hello
Thanks for pointing out my error as I should have thanks all of those individualizes who came to my assistance. Thank you everyone who assistance me in solving this issue.
