if you have a live stream video on the home screen then yes that connection will stay open…to see if you hit that issue check your data usage it will also be high if that is the case.
other than that the app does need to be running in teh background for sensor updates.
you can refer to these steps for battery drain if that is the concern from teh app
I checked the link and I had the Bluetooth Transmitter transmitting all the time and also with high settings. Will see if changing this fix the problem
Regarding the live stream, the problem only happen in the home screen view or also in other view?
basically if you have any live streams you want to make sure that you close the more info panel and also navigate to another view/tab without any streams before putting the app in the background
So to do the test I totally disable everything regarding Bluethoot, the beacon and the monitoring, but the problem is still there, no deep sleep because of the partial wakelock
MmapPlayback
Im sure to get to the home view (no feed there) before sending the app to background.
Will try killing the app before sleep to see if the problem persist
I can’t fix the problem. Already delete the two custom weather cards, also changed the two feed cards from live to auto and they are not in the main view.
The phone won’t enter to deep sleep because of this partial wakelock
Is there a way to directly identify the origin of this MmapPlayback?
