As I had to reinstall Homeassistant quite some times and have lost data during that process I decided to backup my most valuable data (config files and Influxdb) to an USB stick. The original script is available here: https://gist.github.com/riemers/041c6a386a2eab95c55ba3ccaa10e7b0 I just added the line for Influxdb to it.
Only prerequisite is that you have an USB drive formatted and mounted to /media
#!/bin/bash
# Set your paths below. Script can be run from any folder as long as your the right user and the drive is mounted.
# You can either include or exclude the database, incase you have mysql or simply don't want to backup a big file.
# Do check the storage on your drive.
BACKUP_FOLDER=/media/hassbackup/
BACKUP_FILE=${BACKUP_FOLDER}hass-config_$(date +"%Y%m%d_%H%M%S").zip
BACKUP_LOCATION=/home/pi/.homeassistant
INCLUDE_DB=false
DAYSTOKEEP=0 # Set to 0 to keep it forever.
log() {
if [ "${DEBUG}" == "true" ] || [ "${1}" != "d" ]; then
echo "[${1}] ${2}"
if [ "${3}" != "" ]; then
exit ${3}
fi
fi
if [ -d "${BACKUP_FOLDER}" ]; then
if [ ! -d "${BACKUP_LOCATION}" ]; then
log e "Homeassistant folder not found, is it correct?" 1
fi
pushd ${BACKUP_LOCATION} >/dev/null
if [ "${INCLUDE_DB}" = true ] ; then
log i "Creating backup with database"
zip -9 -q -r ${BACKUP_FILE} . -x"components/*" -x"deps/*" -x"home-assistant.log"
else
log i "Creating backup"
zip -9 -q -r ${BACKUP_FILE} . -x"components/*" -x"deps/*" -x"home-assistant.db" -x"home-assistant_v2.db" -x"home-assistant.log"
fi
popd >/dev/null
log i "Backup complete: ${BACKUP_FILE}"
if [ "${DAYSTOKEEP}" = 0 ] ; then
log i "Keeping all files no prunning set"
else
log i "Deleting backups older then ${DAYSTOKEEP} day(s)"
OLDFILES=$(find ${BACKUP_FOLDER} -mindepth 1 -mtime +${DAYSTOKEEP} -delete -print)
if [ ! -z "${OLDFILES}" ] ; then
log i "Found the following old files:"
echo "${OLDFILES}"
fi
fi
else
log e "Backup folder not found, is your USB drive mounted?" 1
fi
sudo influxd backup -portable /media/hassbackup/influxdb
