domieos
(Dominik)
April 15, 2024, 5:53pm
1
Hallo, ich habe leider eine defekte SD-Karte konnte allerdings noch einige Daten von der SD-Karte sichern.
Kann ich mit diesen Daten das System wiederherstellen. Ein Backup gibt es sonst leider nicht. Besten Dank.
Hello, unfortunately I have a defective SD card, but I was still able to save some data from the SD card.
Can I use this data to restore the system? Unfortunately there is no other backup. Thank you very much.
If this is all you have access to I am afraid you have to start from scratch. These files are related to Raspberry Pi, not Home Assistant it seems. Do a search for .yaml and .db to be sure.
domieos
(Dominik)
April 15, 2024, 6:27pm
3
thank you very much, yes apparently everything has been lost due to the SD card error.
Time to set up a new backup regime
You can’t access Linux partitions under Windows.
For those finding this again on Google, the solution was:
Using DiskInternals Linux Reader to access the Linux partitions on a Windows machine . I found a partition with the directory (I know this looks odd, but directly copied from DiskInternals software) “/var/log/journal\supervisor\backup”. It has a lot of tar files that appear to match the “slug” values I saw in the HomeAssistant CLI, so I’m sure these are the backups I made.
I can confirm that inside one of the large tar files I found are …
Or boot a linux live system .
