The backup is faling with the errors below. I know what the devices are on the IP addresses and they are all working fine.
Error creating backup: Backup failed: [{'type': 'HomeAssistantBackupError', 'message': "Can't backup Home Assistant Core config folder: Error adding /data/homeassistant/custom_components/hacs/hacs_frontend/frontend_latest/4768.461587f3e57e00e6.js.gz to tarfile: [Errno 5] I/O error (OSError)", 'stage': 'home_assistant', 'error_key': None, 'extra_fields': None}] 15:32:10 – (ERROR) Backup - message first occurred at 15:18:27 and shows up 4 times
Error querying 192.168.1.135 for modules 'TriggerLogs' on first update: Error querying device: 192.168.1.135: UNSPECIFIC_ERROR(-1001) for method: control_child (error_code=UNSPECIFIC_ERROR) 15:31:01 – (ERROR) components/tplink/coordinator.py - message first occurred at 15:08:40 and shows up 137 times
Error processing TriggerLogs for device 192.168.1.135, module will be disabled: get_trigger_logs for TriggerLogs (error_code=INTERNAL_QUERY_ERROR) 15:31:01 – (ERROR) components/tplink/coordinator.py - message first occurred at 15:31:00 and shows up 5 times
Query failed after successful authentication: Host is 192.168.1.134, Sequence is 517447136, Response status is 403, Request was {"method":"multipleRequest","request_time_milis":1780928801811,"terminal_uuid":"ZRj38DS2kt94gWXbHkgjuw==","params":{"requests":[{"method":"get_device_time"},{"method":"get_auto_off_config","params":{"start_index":0}},{"method":"get_device_info"},{"method":"get_device_usage"}]}} 15:27:48 – (ERROR) components/tplink/coordinator.py - message first occurred at 15:19:05 and shows up 8 times
Error requesting 192.168.1.155 data: Cannot connect to host 192.168.1.155:2323 ssl:False [Connect call failed ('192.168.1.155', 2323)] 15:12:03 – (ERROR) Fully Kiosk Browser
