Hi all,
i have a problem to migrating from Raspberry Pi3 B+ to an Intel NUC i5.
After import the Backup, the HA dont work.
The IP is not the same from NUC
I forget to edit the internal_url, but i go with the terminal on the file here: /usr/share/hassio/homeassistant/configuration.yaml and edit the line to the correct IP. And Restart the NUC.
Docker Containers running:
What can i do? What should I do?
Thanks for help
