Backup integration not available in UI
I am sure, that i had set up my backup earlier this year.
However, since a view days my backup integration does not start anymore. The relevant entry is not shown in the UI either.
Further i do not find any logs regarding backup in CORE or Superviser.
My core is: 2025.1.4
Any ideas to get down to the reason for this?
Hello Dominique,
I believe I saw a message of a user with a similar problem and in the end they did a host reboot (Not just an HA server reload) and that cleared up their problem.
Hi, thank you for the hint. I reviewed the other one, but unfortunately this does not affect my problem.
Is there any log file i can watch? Can I reset the backup settings somewhere? I think it would be good, if HA would at least start the backup integration, but right now it is just not there.
What “backup integration”?
The error message calls it as integration, maybe not correct from a architecture point of view. But anyway, it is totally missing in my UI. Maybe i can get there from a config file or the terminal.
It’s a core integration. I should have realized it before…
Hi, this issue is now stable for weeks. It survives reboots and updates.
Is there any chance to factory reset the backup core module?
regards
