Backup issues
Hi, i have HA running on a rpi3b+ using a kingston ssd.
When i attemp a full backup, i get this:
When exiting settings and going back in, the backup is actually showing.
This didnt happen for the first few backups on to the ssd, but now says it every time. I have no way of checking if the backup is corrupt or not?
This also happened a while back when HA was running off an sd card, and when i tried restoring from the backup, it would just freeze and never restore, so im a bit worried that ill get the same thing now… (to be fair the sd card was half corrupt anyway, but still worried).
I use HA for my diy solar system running the whole house, so is quite important to me that i get this working :sob:…
The supervisor log below:
23-09-09 07:33:48 INFO (MainThread) [supervisor.backups.manager] Found 4 backup files
23-09-09 07:33:48 INFO (MainThread) [supervisor.auth] Successful login for 'mqtt_user'
23-09-09 07:33:50 INFO (MainThread) [supervisor.jobs] 'MountManager.reload' blocked from execution, mounting not supported on system
23-09-09 07:33:52 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-09-09 07:35:16 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-09-09 07:37:32 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/fl4p/home-assistant-addons repository
23-09-09 07:37:32 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repository
23-09-09 07:37:32 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
23-09-09 07:37:32 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
23-09-09 07:37:42 INFO (MainThread) [supervisor.store] Loading add-ons from store: 73 all - 0 new - 0 remove
23-09-09 07:48:50 INFO (MainThread) [supervisor.jobs] 'MountManager.reload' blocked from execution, mounting not supported on system
23-09-09 08:03:50 INFO (MainThread) [supervisor.jobs] 'MountManager.reload' blocked from execution, mounting not supported on system
23-09-09 08:05:17 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-09-09 08:18:50 INFO (MainThread) [supervisor.jobs] 'MountManager.reload' blocked from execution, mounting not supported on system
23-09-09 08:32:22 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
23-09-09 08:32:22 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
23-09-09 08:32:22 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
23-09-09 08:32:22 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.MULTIPLE_DATA_DISKS/ContextType.SYSTEM
23-09-09 08:32:22 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
23-09-09 08:32:22 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
23-09-09 08:32:22 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.NO_CURRENT_BACKUP/ContextType.SYSTEM
23-09-09 08:32:22 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
23-09-09 08:32:22 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
23-09-09 08:32:22 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
23-09-09 08:32:22 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-09-09 08:32:22 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-09-09 08:32:23 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-09-09 08:32:23 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
23-09-09 08:32:23 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-09-09 08:33:50 INFO (MainThread) [supervisor.jobs] 'MountManager.reload' blocked from execution, mounting not supported on system
23-09-09 08:35:18 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-09-09 08:48:34 INFO (MainThread) [supervisor.host.info] Updating local host information
23-09-09 08:48:36 INFO (MainThread) [supervisor.host.services] Updating service information
23-09-09 08:48:36 INFO (MainThread) [supervisor.host.network] Updating local network information
23-09-09 08:48:37 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-09-09 08:48:37 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-09-09 08:48:50 INFO (MainThread) [supervisor.jobs] 'MountManager.reload' blocked from execution, mounting not supported on system
23-09-09 09:03:50 INFO (MainThread) [supervisor.jobs] 'MountManager.reload' blocked from execution, mounting not supported on system
23-09-09 09:05:18 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-09-09 09:18:50 INFO (MainThread) [supervisor.jobs] 'MountManager.reload' blocked from execution, mounting not supported on system
23-09-09 09:21:50 INFO (MainThread) [supervisor.backups.manager] Found 4 backup files
23-09-09 09:22:19 INFO (MainThread) [supervisor.backups.manager] Creating new full backup with slug bbfd2791
23-09-09 09:22:19 INFO (MainThread) [supervisor.backups.manager] Backing up bbfd2791 store Add-ons
23-09-09 09:22:19 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on 5c53de3b_esphome
23-09-09 09:22:19 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon 5c53de3b_esphome
23-09-09 09:22:19 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on core_ssh
23-09-09 09:22:20 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon core_ssh
23-09-09 09:22:55 INFO (SyncWorker_3) [supervisor.docker.manager] Export image <generator object APIClient._stream_raw_result at 0x7fa5efd3f0> to /data/tmp/tmphvevqlp6/image.tar
23-09-09 09:23:09 INFO (SyncWorker_3) [supervisor.docker.manager] Export image <generator object APIClient._stream_raw_result at 0x7fa5efd3f0> done
23-09-09 09:23:09 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on 2af0a32d_batmon
23-09-09 09:27:18 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon 2af0a32d_batmon
23-09-09 09:27:18 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on core_mosquitto
23-09-09 09:27:18 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon core_mosquitto
23-09-09 09:27:18 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on core_configurator
23-09-09 09:27:18 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon core_configurator
23-09-09 09:27:18 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on core_duckdns
23-09-09 09:27:18 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon core_duckdns
23-09-09 09:27:19 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on core_nginx_proxy
23-09-09 09:27:19 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon core_nginx_proxy
23-09-09 09:27:19 INFO (MainThread) [supervisor.homeassistant.module] Backing up Home Assistant Core config folder
23-09-09 09:33:42 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqtt_user'
23-09-09 09:33:43 INFO (MainThread) [supervisor.auth] Successful login for 'mqtt_user'
23-09-09 09:41:43 INFO (MainThread) [supervisor.homeassistant.module] Backup Home Assistant Core config folder done
23-09-09 09:41:43 INFO (MainThread) [supervisor.backups.manager] Backing up bbfd2791 store folders
23-09-09 09:41:43 INFO (SyncWorker_2) [supervisor.backups.backup] Backing up folder share
23-09-09 09:41:43 INFO (SyncWorker_2) [supervisor.backups.backup] Backup folder share done
23-09-09 09:41:43 INFO (SyncWorker_6) [supervisor.backups.backup] Backing up folder addons/local
23-09-09 09:41:43 INFO (SyncWorker_6) [supervisor.backups.backup] Backup folder addons/local done
23-09-09 09:41:43 INFO (SyncWorker_1) [supervisor.backups.backup] Backing up folder ssl
23-09-09 09:41:43 INFO (SyncWorker_1) [supervisor.backups.backup] Backup folder ssl done
23-09-09 09:41:43 INFO (SyncWorker_5) [supervisor.backups.backup] Backing up folder media
23-09-09 09:41:43 INFO (SyncWorker_5) [supervisor.backups.backup] Backup folder media done
23-09-09 09:42:31 INFO (MainThread) [supervisor.backups.manager] Creating full backup with slug bbfd2791 completed
23-09-09 09:43:19 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-09-09 09:44:26 INFO (MainThread) [supervisor.backups.manager] Found 5 backup files
Any ideas?
Somthing to do with these lines? :
23-09-09 09:18:50 INFO (MainThread) [supervisor.jobs] ‘MountManager.reload’ blocked from execution, mounting not supported on system
HA version:
Thank you :+1::+1:
This is a bad error message and should never have gotten past code review.
Please fix then.
I don’t fix problems I didn’t create out of principle.
Just as well others in this community project don’t have that attitude.
The phrase “community project” has no established meaning. What does it mean according to you?
You’re not alone with this problem. I know, doesn’t help very much, but I’d suggest you jump in on the other topic, because there people already try to find a solution. :slight_smile:
Thanks for the replies, but, any idea why this suddenly has started happening? As it didnt before, and i havent updated HA in any way since it worked last… Infact thats the very reason i dont update it, if it aint broke etc…
This isnt since updating to ssd… Ive made bacups no probs since updating to an ssd. Just has suddenly stopped working…
