It will fail since the addons will be missing the associated docker container for the integration to work
There is a way to do this but it will be unique for your install and take a little time
EXAMPLE
A camera in HAOS and docker are same. This will be restored without issue
Zwavejsui requires seperate service to work. This service is installed using a docker container. In docker this container is manually created. In HAOS it is an addon that is automatically created. The configs for these are similar but docker will not have this in backup for HAOS to use when it creates the addon. You will need to setup the addon for first use
For this reason, you can restore the backup and use many of the files but it will not “just work”
pff, thats will be a lot of work!
In my thirst restore trials nothing happened after restoring, so now i start with:
install all integrations manually like solar, p1 etc.
devices: 90% (like 100) of my devices are in an external zigbee2mqtt docker, and they stay there, just for this reason, they come automatic when i connect to mqtt
copy floor and areas
copy automations, script, (bin) sensor, scenes and templates yaml etc.
my dashboards via yaml cut and paste
Last thing thats takes work are
the helpers, like group, numeric boolean and schema
Can i copy these too from a file?
i use a hacs addon for schedules with lots of schedules,
i have to look how to import these after installing the addon manually
When i do a hass backup of my original hass docker version and import this tar file in
the new hassio version, does this import includes
the database
the www folder
the storage folder ?
Last time i tried to backup and retrieve nothing happens…
Now i have first installed ALL the addons, hacs addons on the new system and do another trial of backup and restore.
when the restore adapts something from the original backup i will add and overwrite the special dockers like you said…
another option is to copy the complete original hass folder over the hassio folder…
problem is that the database is still active during copy.
Option to close hassio kills my winscp and then i cant copy…
