Backup restore hangs
I created/downloaded a full backup on 9 dec , reinstalled HA on my SSD. and when that started used the restore option to restore that backup (930 Mb) . Now 10 hours later it is still on that page in the UI.
If I look in the console, there are no errors and it looks like I can still give commands.
For example su logs:
Is there anyway to find out what is going on? I saw this in other topics, some feedback during a restore would be really helpful. Is the restore doing something? I leave it going hoping someone can tell me how to check this.
BTW , the backup was already on the latest versions of everything that was than available, I made the backup just after a full upgrade of all outstanding new versions.
There is no way to see if it actually is doing something? Is there a way to see the homeassistant.log from the console?
Very frustrating that nobody seems to be able to help me here. The reason I started from scratch with that backup is that I saw in the console that there were disk errors. So cleaned the disk , installed HA on it and then immidiately tried the restore. As I said it was still busy after 24 hours. And although there were no errors in the console , the only thing I could think of is that the restore was failing because the disk was failing again. So I bought a new SSD . but I am under the impression it is doing the same thing: “nothing”. So please, any hints on how to check what it IS doing? This is the content of the tar file I am trying to restore. That is correct?
I’m having the same issue. Maybe filing a bug report would make sense. I’m going to wait a few hours but I’m pretty sure nothing is happening.
Same issue here. Over 15 hours restoring and GUI still not responding.
CLI works, though, but any intent to run the restore command from the CLI ends up with a 404 error.
