Hi community,
for quite some time now i used the Samba Backup Addon to backup my HA on a daily basis and mirror the backup to my Synology DS. Some days ago it suddenly stopped working and I can’t figure out, why. As manual Backups via HA UI (Configuration > Backups > Create Backup) and also via Terminal (ha backups new) don’t work, I think I might have an issue with the filesystem / the database (see logs below. Over the weekend (just before the backups stopped working) I added some new Zigbee-Devices and activated the energy dashboard.
Supervisor Log
22-03-04 00:30:50 WARNING (MainThread) [supervisor.homeassistant.module] Error during Home Assistant Core backup. Check HA Core logs.
22-03-04 00:30:50 ERROR (MainThread) [supervisor.backups.manager] Backup 4e2682e5 error
File "/usr/src/supervisor/supervisor/backups/manager.py", line 149, in _do_backup
await backup.store_homeassistant_config_dir()
File "/usr/src/supervisor/supervisor/backups/backup.py", line 486, in store_homeassistant_config_dir
await self.sys_homeassistant.backup(homeassistant_file)
File "/usr/src/supervisor/supervisor/homeassistant/module.py", line 330, in backup
await self.sys_run_in_executor(_write_tarfile)
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
File "/usr/src/supervisor/supervisor/homeassistant/module.py", line 321, in _write_tarfile
atomic_contents_add(
File "/usr/src/supervisor/supervisor/utils/tar.py", line 180, in atomic_contents_add
tar_file.add(directory_item.as_posix(), arcname=arcpath, recursive=False)
File "/usr/local/lib/python3.9/tarfile.py", line 1963, in add
tarinfo = self.gettarinfo(name, arcname)
File "/usr/local/lib/python3.9/tarfile.py", line 1842, in gettarinfo
statres = os.lstat(name)
FileNotFoundError: [Errno 2] No such file or directory: '/data/homeassistant/zigbee.db-journal'
22-03-04 00:32:12 INFO (MainThread) [supervisor.backups.manager] Creating new full backup with slug a6d88b2e
22-03-04 00:32:12 INFO (MainThread) [supervisor.backups.manager] Backing up a6d88b2e store Add-ons
22-03-04 00:32:13 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on core_configurator
22-03-04 00:32:13 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon core_configurator
Core Log
2022-03-04 00:30:50 WARNING (MainThread) [homeassistant.components.recorder] Database currently not locked
2022-03-04 00:30:50 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /backups/new/full - Unknown error, see supervisor
2022-03-04 00:30:56 WARNING (SyncWorker_0) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2022-03-04 00:31:26 WARNING (SyncWorker_6) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2022-03-04 00:31:56 WARNING (SyncWorker_7) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2022-03-04 00:32:26 WARNING (SyncWorker_1) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2022-03-04 00:32:56 WARNING (SyncWorker_3) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2022-03-04 00:33:26 WARNING (SyncWorker_2) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2022-03-04 00:33:56 WARNING (SyncWorker_0) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2022-03-04 00:34:26 WARNING (SyncWorker_5) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2022-03-04 00:34:56 WARNING (SyncWorker_6) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2022-03-04 00:35:26 WARNING (SyncWorker_4) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2022-03-04 00:35:56 WARNING (SyncWorker_7) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2022-03-04 00:36:26 WARNING (SyncWorker_0) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2022-03-04 00:36:51 WARNING (MainThread) [homeassistant.components.recorder] Database currently not locked
2022-03-04 00:36:56 WARNING (SyncWorker_8) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2022-03-04 00:37:26 WARNING (SyncWorker_6) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2022-03-04 00:37:56 WARNING (SyncWorker_9) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2022-03-04 00:38:26 WARNING (SyncWorker_7) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2022-03-04 00:38:56 WARNING (SyncWorker_1) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2022-03-04 00:39:36 WARNING (SyncWorker_5) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2022-03-04 00:40:06 WARNING (SyncWorker_4) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2022-03-04 00:40:36 WARNING (SyncWorker_8) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
Thanks for any hints in advance!!
//EDIT
Forgot to give my system specs:
System Health
version: core-2022.2.5
installation_type: Home Assistant OS
dev: false
hassio: true
docker: true
user: root
virtualenv: false
python_version: 3.9.7
os_name: Linux
os_version: 5.10.92-v8
arch: aarch64
timezone: Europe/Berlin
logged_in: false
can_reach_cert_server: ok
can_reach_cloud_auth: ok
can_reach_cloud: ok
host_os: Home Assistant OS 7.4
update_channel: stable
supervisor_version: supervisor-2022.01.1
docker_version: 20.10.9
disk_total: 14.1 GB
disk_used: 4.6 GB
healthy: true
supported: true
board: rpi3-64
supervisor_api: ok
version_api: ok
installed_addons: File editor (5.3.3), Samba Backup (5.0.0), Terminal & SSH (9.3.0)
dashboards: 2
resources: 0
mode: storage
