Either way I set the path in the backup GUI (NAS or SD card) and no matter how often I hit reload or copy a tar file to the sd cards backup folder - it keeps saying that I have no backups.
Any ideas how to resolve this or is this a known bug?
I’m having the same issue, I can see the backups on my NAS. They used to take a few seconds to show up in the HA ui, but now they don’t show at all.
Just notice this Config Difference for the two Different Platforms.
My PC Username is “Phil”, Password “Pwd#1”.
Both external Storages are configured with the above.
For the Samba Add-On Though,
rPi is configured with “Phil” & “Pwd#1”,
but
Nuc has it’s Samba Add-On configured with “Hass” & “Pwd#2”.
Might investigate that further, it may be relevant.???
On my side, i had the same issue until i deleted older backups that had no time in the date.
For older backup the date of the files where “11/12/2022” and for newer files i had the time also “11/12/2022 11:22:33”. By just deleting all the files that didn’t had any time i solved the issue.
I suppose that at one time the time was not saved correctly, which was fixed afterwards, but the old backups without time where disturbing the process.
Just ran into the same problem. After fiddling around a bit I get the strong imprssion that as soon as there are one or more backup files that are present in both the local storage and the network storage (i.e. duplicates) no backups are shown in HA. Remove the duplicates, and it works again. You may want consider this a bug as it is highly unexpected and confusing.
I had 59 backup .tar files in my network backup directory. Kept the 3 most recent, deleted the 56 others and that fixed the issue. Backups are now displayed after 3-5 seconds.
I am storing the backup also via SMB on my QNAP NAS. My Home Assistant OS is running on a proxmox server.
Until today the backups are always shown, but starting from today the page shows nothing.
I cleared the browser cache, used differnet Home Assistant Companion apps on iOS/iPadOS/macOS and Android, nothing can be seen.
I see that the backups are created by the daily automation and also when I am creating a backup by hand.
But the page stays empty. I only have seven backups on the NAS.
Home Assistant OS: 13.0
Core: 2024.8.1
Supervisor: 2024.08.0
same experience as other people here, likely related to the number of backups. clearing old backups from my NAS resolves the issue, now I just have my new generational backups stored, which also ensures it will never be that many again.
Creating backups both on the system drive and a NAS, which from there get`s copied (not moved) into an iCloud folder on my Mac. HA never had knowledge of the ladder, but always displayed all backups from system drive and NAS. Both system drive and NAS are in good condition and have plenty of space.
I am observing this behavior since the latest core update to 2024.9.2
Deleting 30 out of 70 backups did not help.
