Hi!
I hope someone can point me in the right direction. After a Pi restart I’ve encountered several errors and I can’t find the origin.
My Raspberry Pi 3 is running Home Assistant OS with the latest versions (as of a few days ago). I’ve been running it succesfully for a few months now. Since a restart two days ago, every time I try to access the web interface, I get a “500 internal server error / server got itself in trouble” error.
Here are some details.
Every few seconds, /config/home-assistant.log adds this message:
2022-02-09 23:23:58 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 80, in forwarded_middleware
from hass_nabucasa import ( # pylint: disable=import-outside-toplevel
File "/usr/local/lib/python3.9/site-packages/hass_nabucasa/__init__.py", line 15, in <module>
from .auth import CloudError, CognitoAuth
File "/usr/local/lib/python3.9/site-packages/hass_nabucasa/auth.py", line 7, in <module>
import boto3
File "/usr/local/lib/python3.9/site-packages/boto3/__init__.py", line 16, in <module>
from boto3.session import Session
File "/usr/local/lib/python3.9/site-packages/boto3/session.py", line 17, in <module>
import botocore.session
File "/usr/local/lib/python3.9/site-packages/botocore/session.py", line 30, in <module>
import botocore.client
File "/usr/local/lib/python3.9/site-packages/botocore/client.py", line 26, in <module>
from botocore.model import ServiceModel
File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 680, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 846, in exec_module
File "<frozen importlib._bootstrap_external>", line 978, in get_code
File "<frozen importlib._bootstrap_external>", line 647, in _compile_bytecode
SystemError: Objects/codeobject.c:141: bad argument to internal function
As the last thing I did was add the Spotify integration (although that seemed successful), I tried removing its entry in /config/.storage/core.config_entries, to no avail. I also set http.ip_ban_enabled to false in my /config/configuration.yaml, as some topics mentioned that a self-banned ip could be the issue.
Note that I also cannot create a backup with the ha backup new command, because of an “unknown error, see supervisor”. When checking the logs of the supervisor, it contains this entry:
INFO (MainThread) [supervisor.jobs] 'BackupManager.do_backup_full' blocked from execution, system is not running - CoreState.STARTUP
And also this message, every 5 seconds:
ERROR (MainThread) [supervisor.homeassistant.api] Can't update Home Assistant access token!
When I try to start the core with ha core start I get another unknown error and the supervisor logs show this:
ERROR (MainThread) [supervisor.utils] Can't execute start while a task is in progress
Does anyone have an idea of where to look or what to try? My search efforts of all the mentioned errors did not result in anything. It feels like the fix is super simple, but I don’t know what my next step could be. Any suggestions?
