Logger: homeassistant.setup
Source: setup.py:162
First occurred: 12:16:34 PM (1 occurrences)
Last logged: 12:16:34 PM
Setup failed for custom integration entity_controller: Unable to import component: Unable to import component: cannot import name ‘Machine’ from ‘transitions’ (/usr/local/lib/python3.9/site-packages/transitions/init.py)
I had machine failure yesterday (ECC memory died) and this could be related. I saved the VM from the old harddisk and have started rebuilding on a new machine. Anyone have an idea what is wrong and what needs to be done?
I don’t think it is a bug. It was working and then it didn’t. I am on 2022.05.04. I have updated everything I could. I removed the entity controller from hacs and now I get this in my error messages.
2022-05-16 13:03:58 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration entity_controller which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-05-16 13:06:56 ERROR (MainThread) [homeassistant.components.hassio] The system cannot restart because the configuration is not valid: Component error: entity_controller - No module named ‘custom_components.entity_controller’
2022-05-16 13:06:56 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [139818723909536] The system cannot restart because the configuration is not valid: Component error: entity_controller - No module named ‘custom_components.entity_controller’
homeassistant.exceptions.HomeAssistantError: The system cannot restart because the configuration is not valid: Component error: entity_controller - No module named ‘custom_components.entity_controller’
2022-05-16 13:10:40 ERROR (MainThread) [homeassistant.setup] Setup failed for entity_controller: Integration not found.
It was working and I was trying to rebuild my energy (integration, sensors and utility meters) system and the original problem occurred.
I have it working again. The entity_controller was in hacs. I removed it and all configuration references and it is running. I will reinstall as needed.
