Hey,
I’d like to do this Weather badge like in this picture (4th), with the dynamic icon based on weather and the temperature in a label.
Thanks for your help
@Mariusthvdb
Hey,
@Mariusthvdb
sure, here you go:
its a template sensor:
weather_animated_icon:
friendly_name_template: >
{{states('sensor.dark_sky_forecast_icon')|capitalize|replace('-',' ')}}
value_template: >
entity_picture_template: >
{% set mapper =
{ 'breezy':'cloudy',
'clear-night':'night',
'clear':'day',
'mostly-clear':'day',
'clear-day':'day',
'cloudy':'cloudy',
'fog':'fog',
'hail':'rainy-7',
'haze':'haze',
'lightning':'thunder',
'mostly-cloudy':'cloudy',
'partly-cloudy':'cloudy-day-3',
'partly-cloudy-day':'partly-cloudy-day',
'partly-cloudy-night':'partly-cloudy-night',
'rain':'rainy-4',
'scattered-showers':'rainy-3',
'showers':'rainy-6',
'sleet':'sleet',
'snow':'snowy-6',
'mostly-sunny':'day',
'sunny':'day',
'thunderstorm':'thunder',
'tornado':'tornado',
'wind':'wind',
'windy':'wind'} %}
{% set state = states('sensor.dark_sky_icon') %}
{% set weather = mapper[state] if state in mapper else 'weather' %}
{% set path = '/local/weather/animated/' %}
{% set ext = '.svg'%}
{{[path,weather,ext]|join('')}}
using the Amcharts animated icons
the badge label (used for unit_of_measurement) is customized, and in this case with custom-ui.
homeassistant:
customize:
sensor.weather_animated_icon:
templates:
unit_of_measurement: >
if (entities['sensor.temp_current'])
return entities['sensor.temp_current'].state +' °C';
return 'Initializing';
cheers!
we might ask @Ildar_Gabdullin whether our journey with card-mod’ing the badges also enables the template for the temperature in the label.
card-mod is a modern way of modding the HA frontend.
Cannot check it by myself since I have not installed Custom_UI so far…
But here there is a description of styling badges - and I think this will work with templates as well, need to try.
Hey @Mariusthvdb,
So i have been trying to set this badge.
I put the animated icons in the /local/weather/animated folder
And when i restarted home assistant sensor.weather_animated_icon is Unknown.
I haven’t setup custom yet.
Best regards
