For those (like me) who are having trouble putting the pieces together enough to connect to their P1P via MQTT, here’s what worked for me, in the form of images:
Then click Advanced and remove the default topics, replacing with device/YOUR_SERIAL_HERE/report :
Then go back and connect, and you’ll see something like this:
It looks like certain status info can be scraped from strings if desired, such as these:
"mc_print": {
"param": "[BMC] Print percent:83.00%,0h34m left line=263739",
"command": "push_info",
"sequence_id": "80550"
01/22/2023 6:14:41 PM
{"mc_print":{"param":"[AMS][TASK]tray_exist:0x0;tray_read_done:0x0,vailed:0x0,reading:0x0","command":"push_info","sequence_id":"80575"}}
01/22/2023 6:14:41 PM(-0 seconds)
{"mc_print":{"param":"[AMS][TASK]ams num:0,ams_exist:0x0,tray_now: 255","command":"push_info","sequence_id":"80574"}}
{"mc_print":{"param":"[AMS][Period]:len=0.000m;buf=0.00;hall_e=20mV,cut=1547mV","command":"push_info","sequence_id":"80573"}}
{"mc_print":{"param":"[AMS][Period]:bldc_i=0.00,u=0.00,spd=0.00;dw_spd=0.00;bdc_i=0.00,u=0.00,spd=0.00","command":"push_info","sequence_id":"80572"}}
