Bambulab Print live Notification
This is my firs blueprint so I hope it works…
blueprint:
  name: 3D Print Progress (Bambu)
  description: >
    Live Android notification with progress bar and countdown
    for Bambu Lab printers.
  domain: automation
  input:
    progress_sensor:
      name: Print Progress Sensor
      description: Sensor with print progress in percent (0–100)
      selector:
        entity:
          domain: sensor
    status_sensor:
      name: Print Status Sensor
      description: Sensor that reports "Finished" when the print is done
      selector:
        entity:
          domain: sensor
    remaining_time_sensor:
      name: Remaining Time Sensor
      description: Sensor with remaining time in minutes
      selector:
        entity:
          domain: sensor
    notify_target:
      description: e.g. notify.mobile_app_a142
      selector:
        text:
alias: 3D Print Progress
description: ""
triggers:
  - trigger: state
    entity_id:
      - !input progress_sensor
      - !input status_sensor
      - !input remaining_time_sensor
conditions: []
actions:
  - choose:
      - conditions:
          - condition: template
            value_template: >-
              {{ trigger.entity_id == config.inputs.status_sensor and
              trigger.to_state.state == 'Finished' }}
        sequence:
          - action: !input notify_target
              title: "3D Print complete ✅"
              message: "Your print is done!"
                tag: 3d_print_progress
                live_update: true
                progress: 100
                progress_max: 100
          - delay:
              seconds: 5
              message: clear_notification
    default:
          title: "3D Print in progress 🖨️"
          message: >-
            {% set s = states(config.inputs.remaining_time_sensor) | int %}
            {{ s // 60 }}:{{ '%02d' | format(s % 60) }} remaining –
            {{ states(config.inputs.progress_sensor) | int }} %
            progress: >-
            progress_max: 100
            live_update: true
            silent: true
            alert_once: true
            sticky: true
            notification_icon: mdi:printer-3d-nozzle
            chronometer: true
            when: >-
              {{ (now().timestamp() + states(config.inputs.remaining_time_sensor) | int * 60) | int }}
mode: single
Hello Peter Schmidt,
Welcome to the Home Assistant Forum!
Thanks for contributing to the community with a new Blueprint.
First, what does that mean?
Did you write this or someone/something else?
Did you test it?
If you use AI you have to disclose it.
I have a suggestion for you. Many people who are not familiar with directory structures will have problems installing this without the Home Assistant MY tools.
Adding a MY link for this Blueprint to your top post would help them a lot.
Here is the link to make that.
Create a link – My Home Assistant
