I could not find a lovelace card to show barchart for daily output and I couldn’t modify mini-graph-card with my limited programming ability. Hence made an app to show bar chart of my Daily Power Output as an Image
# -*- coding: utf-8 -*-
"""App to plot monthly data from InfluxDB.
Args:
class: InfluxChart
module: influx_chart
host: localhost #influxdb host
user: home_assistant #influxdb user name
password: 'pwd' #influxdb pwd
dbname: home_assistant #influxdb db name
query: "select max(value) from kWh where entity_id = 'energy_generation' and time >= now() - 30d group by time(1d) fill(null) order by time asc;"
import appdaemon.plugins.hass.hassapi as hass
from influxdb import InfluxDBClient
import datetime
import matplotlib.pyplot as plt
class InfluxChart(hass.Hass):
def initialize(self):
self.log("Hello from InfluxChart Data Plot App")
self.host = self.args.get("host", "localhost")
port=8086
self.user = self.args.get("user", "home_assistant")
self.password = self.args.get("password", None)
self.dbname = self.args.get("dbname", "home_assistant")
self.query = self.args.get("query", None)
#run at midnight
self.run_daily(self.create_chart, datetime.time(23, 55, 0))
def create_chart(self, kwargs):
self.log("Querying data: ")
"""Instantiate a connection to the InfluxDB."""
client =InfluxDBClient(self.host, port, self.user, self.password, self.dbname)
result = client.query(self.query)
resultInList = list(result.get_points(measurement='kWh'))
data = {}
for p in resultInList:
d = p['time']
mt = d.split('-')[1]
dt = ((d.split('-')[2].split(':')[0])).split('T')[0]
k = "{}/{}".format(mt,dt)
data[k] = p['max']
names = list(data.keys())
values = list(data.values())
self.plot_bar_chart(values, names, data)
def plot_bar_chart(self,values, labels, data):
#set tick label font size
plt.rc('xtick',labelsize=6)
plt.rc('ytick',labelsize=6)
#Plot size
plt.figure(figsize=(6,3.5))
h = plt.bar(range(len(labels)), values, label=labels, color='#039BE5')
plt.subplots_adjust(bottom=0.3)
ax = plt.gca()
xticks_pos = [0.5*patch.get_width() + patch.get_xy()[0] for patch in h]
plt.xlim([-0.5,len(labels)-0.5])
#hide top and right axis lines
ax.spines['top'].set_visible(False)
ax.spines['right'].set_visible(False)
#plt.tick_params(axis="both", which="both", bottom="on", top="off",
#labelbottom="on", left="on", right="off", labelleft="on")
#rotate bottom tick labels
plt.xticks(xticks_pos, labels, ha='center', rotation=90, fontsize=6)
#y axis label
plt.ylabel('kWh', fontsize=10)
plt.title('DAILY ELECTRICITY OUTPUT', fontsize=10)
#plt.savefig('top_words.png', bbox_inches='tight')
plt.savefig('/home/anilet/appdaemon/conf/apps/influx_chart/bar.png', bbox_inches='tight')
