Could someone recommend an outdoor barometric pressure sensor. Zigbee or 433mhz. The only thing I’ve found is the aqara temperature and humidity sensor. It has pressure measurement but it’s not advertised for some reason and it’s an indoor sensor.
I use the Aqara temp/humidity/pressure sensors all over the house. Three are in sheds or completely outdoors. The outdoor ones are not directly exposed, they are either under a porch railing or under an eve. They have been working fine for over 3 years now.
I am in Central Texas (Hill Country). Environment is 20-105 degrees F. and 5-100% humidity.
Why does it have to be outdoors? Unless you’re living in a pressure or vacuum chamber, the inside and outside pressures should be the same…
I guess it does not have to be outside.
